debug ip icmp --> does not show me results
mohammed hashim
hi,
between two routers:
R12------R10-------Host1
R12 and R10 are on subnet 10.0.102.0/24
R10 loopback is 10.10.10.10/32
Host1 is 10.0.10.100
I want to see debug ip icmp, but it does not show me anything when I:
R12:
R12#ping 10.10.10.10
Sending 5, 100-byte ICMP Echos to 10.10.10.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/3 ms
R12#
R12#
R12#ping 10.0.102.10
Sending 5, 100-byte ICMP Echos to 10.0.102.10, timeout is 2 seconds:
R12#
R12#
R12#ping 10.0.10.100
Sending 5, 100-byte ICMP Echos to 10.0.10.100, timeout is 2 seconds:
R12#
R10:
R10#debug ip packet detail 199
IP packet debugging is on (detailed) for access list 199
R10#
R10#
R10#debug ip icmp
ICMP packet debugging is on
R10#show access-lists 199
Extended IP access list 199
10 permit icmp any any
however, when I clear debug, and use debug ip packet without filtering, then I do see ospf routing packets, it means there is no issue in terminal monitor
7 Replies 7
Hello
Try ..
terminal monitor
conf t
logging console 7
or
logging console debugging
res
Paul
Kind Regards
Paul
Hi Paul,
thanks for reply
but it did not help
could it be platform issue?
I am using CSR 1000v:
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-ADVENTERPRISEK9-M), Version
IOS XE Version: 03.09.00a.S
Hello
humm - try
no logging console disable
show logging
res
paul
Kind Regards
Paul
did not help,
I also tried logging buffer 7,
show logging, has nothing,
did you read my second reply?
it is working fine with other IOS
Hello
seems odd ...okay - I guess your able to get into  exec mode
what privilage level do you have?
sh privilege level
sh running- confighello hello s
paul
Kind Regards
Paul
R10#show privilege
Current privilege level is 15
what do you mean by
it looks like platform issue, because I just tried with
(C7200-ADVENTERPRISEK9-M), Version 15.3(3)XB12
and it is working fine
