Debug IP icmp....
arind123m
Need  help for resolving this issue
Infrastructure..
We have one RouterA ----Fa2/0.202------------connected to Switch(Gi0/2)-----------------RouterB(Gi1/7)
IF i try to ping from Router A to Router B, getting request timed out...I have done the debug also...but still unable to resolve that.
Need your help.....
Debug--ip icmp
Oct  6 02:13:53 IST:     ICMP type=8, code=0
Oct  6 02:13:53 IST: IP: s=200.200.200.18 (local), d=200.200.200.21 (FastEthernet2/0.202), len 100, encapsulation failed
Oct  6 02:13:55 IST: IP: tableid=0, s=200.200.200.18 (local), d=200.200.200.21 (FastEthernet2/0.202), routed via RIB
Oct  6 02:13:55 IST: IP: s=200.200.200.18 (local), d=200.200.200.21 (FastEthernet2/0.202), len 100, sending
Oct  6 02:13:55 IST:     ICMP type=8, code=0
Oct  6 02:13:55 IST: IP: s=200.200.200.18 (local), d=200.200.200.21 (FastEthernet2/0.202), len 100, encapsulation failed
Oct  6 02:13:57 IST: IP: tableid=0, s=200.200.200.18 (local), d=200.200.200.21 (FastEthernet2/0.202), routed via RIB
Oct  6 02:13:57 IST: IP: s=200.200.200.18 (local), d=200.200.200.21 (FastEthernet2/0.202), len 100, sending
Oct  6 02:13:57 IST:     ICMP type=8, code=0
Oct  6 02:13:57 IST: IP: s=200.200.200.18 (local), d=200.200.200.21 (FastEthernet2/0.202), len 100, encapsulation failed
Oct  6 02:13:59 IST: IP: tableid=0, s=200.200.200.18 (local), d=200.200.200.21 (FastEthernet2/0.202), routed via RIB
Oct  6 02:13:59 IST: IP: s=200.200.200.18 (local), d=200.200.200.21 (FastEthernet2/0.202), len 100, sending
Oct  6 02:13:59 IST:     ICMP type=8, code=0
Oct  6 02:13:59 IST: IP: s=200.200.200.18 (local), d=200.200.200.21 (FastEthernet2/0.202), len 100, encapsulation failed
Oct  6 02:14:01 IST: IP: tableid=0, s=200.200.200.18 (local), d=200.200.200.21 (FastEthernet2/0.202), routed via RIB
Oct  6 02:14:01 IST: IP: s=200.200.200.18 (local), d=200.200.200.21 (FastEthernet2/0.202), len 100, sending
Oct  6 02:14:01 IST:     ICMP type=8, code=0
Oct  6 02:14:01 IST: IP: s=200.200.200.18 (local), d=200.200.200.21 (FastEthernet2/0.202), len 100, encapsulation failed
Hello Arindam,
First of all remember to rate all of the helpful posts.
now going to your scenario, Encapsulation failed messages in this scenarios let us know that the packet knows where to send the packet but it does now know how to do it.
We are handeling an Ethernet network so we are having some troubles with ARP.
We basically do not know what's the MAC addres of the IP address we are trying to ping so we are unable to build the L2 information for the packet hence "encapsulation failed"
That being said make sure the L2 network is properly designed (Check Trunk links, Port-status, VLAN databases, etc) afterwards you should be good my friend.
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
acampbell
Arindam,
Can you post the configs of
Router A int fas 2/0.202
Both switch port configs
Router B int gi1/7
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Thankz Alex....
Now I am facing another issue, I have resolved the issue by doing shut/unshut  Subinterfaces and also reconfigured encapsulation dot1q tag... Now i am able to ping from Router A to Router B,
But now im not able to ping Router-B to Router A(reverse)
Debug ouput in reverse direction....
Oct  6 05:38:58: FIBipv4-packet-proc: route packet from (local) src 200.200.200.21 dst 200.200.200.18
Oct  6 05:38:58: FIBfwd-proc: Default:200.200.200.0/24 proces level forwarding
Oct  6 05:38:58: FIBfwd-proc: depth 0 first_idx 0 paths 1 long 0(0)
Oct  6 05:38:58: FIBfwd-proc: try path 0 (of 1) v4-con-Vlan201 first short ext 0(-1)
Oct  6 05:38:58: FIBfwd-proc: v4-con-Vlan201 valid
Oct  6 05:38:58: FIBfwd-proc: Vlan201 no nh type 2  - deag
Oct  6 05:38:58: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none deag 1 chg_if 0 via fib 0 path type connected prefix
Oct  6 05:38:58: FIBfwd-proc: packet routed to Vlan201 p2p(0)
Oct  6 05:38:58: FIBipv4-packet-proc: packet routing succeeded
Oct  6 05:38:58: IP: tableid=0, s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), routed via FIB
Oct  6 05:38:58: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none uhp 1 deag 0 ttlexp 0
Oct  6 05:38:58: FIBfwd-proc: sending link IP ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none uhp 1 deag 0 chgif 0 ttlexp 0 rec 0
Oct  6 05:38:58: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, sending
Oct  6 05:38:58:     ICMP type=8, code=0
Oct  6 05:38:58: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, output feature
Oct  6 05:38:58:     ICMP type=8, code=0, HW Shortcut Installation(66), rtype 1, forus FALSE, sendself FALSE, mtu 0
Oct  6 05:38:58: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, encapsulation failed
Oct  6 05:38:58:     ICMP type=8, code=0.
Oct  6 05:39:00: FIBipv4-packet-proc: route packet from (local) src 200.200.200.21 dst 200.200.200.18
Oct  6 05:39:00: FIBfwd-proc: Default:200.200.200.0/24 proces level forwarding
Oct  6 05:39:00: FIBfwd-proc: depth 0 first_idx 0 paths 1 long 0(0)
Oct  6 05:39:00: FIBfwd-proc: try path 0 (of 1) v4-con-Vlan201 first short ext 0(-1)
Oct  6 05:39:00: FIBfwd-proc: v4-con-Vlan201 valid
Oct  6 05:39:00: FIBfwd-proc: Vlan201 no nh type 2  - deag
Oct  6 05:39:00: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none deag 1 chg_if 0 via fib 0 path type connected prefix
Oct  6 05:39:00: FIBfwd-proc: packet routed to Vlan201 p2p(0)
Oct  6 05:39:00: FIBipv4-packet-proc: packet routing succeeded
Oct  6 05:39:00: IP: tableid=0, s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), routed via FIB
Oct  6 05:39:00: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none uhp 1 deag 0 ttlexp 0
Oct  6 05:39:00: FIBfwd-proc: sending link IP ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none uhp 1 deag 0 chgif 0 ttlexp 0 rec 0
Oct  6 05:39:00: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, sending
Oct  6 05:39:00:     ICMP type=8, code=0
Oct  6 05:39:00: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, output feature
Oct  6 05:39:00:     ICMP type=8, code=0, HW Shortcut Installation(66), rtype 1, forus FALSE, sendself FALSE, mtu 0
Oct  6 05:39:00: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, encapsulation failed
Oct  6 05:39:00:     ICMP type=8, code=0.
Oct  6 05:39:02: FIBipv4-packet-proc: route packet from (local) src 200.200.200.21 dst 200.200.200.18
Oct  6 05:39:02: FIBfwd-proc: Default:200.200.200.0/24 proces level forwarding
Oct  6 05:39:02: FIBfwd-proc: depth 0 first_idx 0 paths 1 long 0(0)
Oct  6 05:39:02: FIBfwd-proc: try path 0 (of 1) v4-con-Vlan201 first short ext 0(-1)
Oct  6 05:39:02: FIBfwd-proc: v4-con-Vlan201 valid
Oct  6 05:39:02: FIBfwd-proc: Vlan201 no nh type 2  - deag
Oct  6 05:39:02: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none deag 1 chg_if 0 via fib 0 path type connected prefix
Oct  6 05:39:02: FIBfwd-proc: packet routed to Vlan201 p2p(0)
Oct  6 05:39:02: FIBipv4-packet-proc: packet routing succeeded
Oct  6 05:39:02: IP: tableid=0, s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), routed via FIB
Oct  6 05:39:02: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none uhp 1 deag 0 ttlexp 0
Oct  6 05:39:02: FIBfwd-proc: sending link IP ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none uhp 1 deag 0 chgif 0 ttlexp 0 rec 0
Oct  6 05:39:02: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, sending
Oct  6 05:39:02:     ICMP type=8, code=0
Oct  6 05:39:02: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, output feature
Oct  6 05:39:02:     ICMP type=8, code=0, HW Shortcut Installation(66), rtype 1, forus FALSE, sendself FALSE, mtu 0
Oct  6 05:39:02: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, encapsulation failed
Oct  6 05:39:02:     ICMP type=8, code=0.
Oct  6 05:39:04: FIBipv4-packet-proc: route packet from (local) src 200.200.200.21 dst 200.200.200.18
Oct  6 05:39:04: FIBfwd-proc: Default:200.200.200.0/24 proces level forwarding
Oct  6 05:39:04: FIBfwd-proc: depth 0 first_idx 0 paths 1 long 0(0)
Oct  6 05:39:04: FIBfwd-proc: try path 0 (of 1) v4-con-Vlan201 first short ext 0(-1)
Oct  6 05:39:04: FIBfwd-proc: v4-con-Vlan201 valid
Oct  6 05:39:04: FIBfwd-proc: Vlan201 no nh type 2  - deag
Oct  6 05:39:04: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none deag 1 chg_if 0 via fib 0 path type connected prefix
Oct  6 05:39:04: FIBfwd-proc: packet routed to Vlan201 p2p(0)
Oct  6 05:39:04: FIBipv4-packet-proc: packet routing succeeded
Oct  6 05:39:04: IP: tableid=0, s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), routed via FIB
Oct  6 05:39:04: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none uhp 1 deag 0 ttlexp 0
Oct  6 05:39:04: FIBfwd-proc: sending link IP ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none uhp 1 deag 0 chgif 0 ttlexp 0 rec 0
Oct  6 05:39:04: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, sending
Oct  6 05:39:04:     ICMP type=8, code=0
Oct  6 05:39:04: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, output feature
Oct  6 05:39:04:     ICMP type=8, code=0, HW Shortcut Installation(66), rtype 1, forus FALSE, sendself FALSE, mtu 0
Oct  6 05:39:04: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, encapsulation failed
Oct  6 05:39:04:     ICMP type=8, code=0.
Oct  6 05:39:06: FIBipv4-packet-proc: route packet from (local) src 200.200.200.21 dst 200.200.200.18
Oct  6 05:39:06: FIBfwd-proc: Default:200.200.200.0/24 proces level forwarding
Oct  6 05:39:06: FIBfwd-proc: depth 0 first_idx 0 paths 1 long 0(0)
Oct  6 05:39:06: FIBfwd-proc: try path 0 (of 1) v4-con-Vlan201 first short ext 0(-1)
Oct  6 05:39:06: FIBfwd-proc: v4-con-Vlan201 valid
Oct  6 05:39:06: FIBfwd-proc: Vlan201 no nh type 2  - deag
Oct  6 05:39:06: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none deag 1 chg_if 0 via fib 0 path type connected prefix
Oct  6 05:39:06: FIBfwd-proc: packet routed to Vlan201 p2p(0)
Oct  6 05:39:06: FIBipv4-packet-proc: packet routing succeeded
Oct  6 05:39:06: IP: tableid=0, s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), routed via FIB
Oct  6 05:39:06: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none uhp 1 deag 0 ttlexp 0
Oct  6 05:39:06: FIBfwd-proc: sending link IP ip_pak_table 0 ip_nh_table 65535 if Vlan201 nh none uhp 1 deag 0 chgif 0 ttlexp 0 rec 0
Oct  6 05:39:06: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, sending
Oct  6 05:39:06:     ICMP type=8, code=0
Oct  6 05:39:06: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, output feature
Oct  6 05:39:06:     ICMP type=8, code=0, HW Shortcut Installation(66), rtype 1, forus FALSE, sendself FALSE, mtu 0
Oct  6 05:39:06: IP: s=200.200.200.21 (local), d=200.200.200.18 (Vlan201), len 100, encapsulation failed
Oct  6 05:39:06:     ICMP type=8, code=0.
Success rate is 0 percent (0/5)
CRTR103#unde all
All possible debugging has been turned off
CRTR103#
Hello Arindam,
Cheers,
Julio Carvajal
Router A- Switch-Router B
Configuration of all three devices.
Problem : Am able to ping Router A to Router B, but unable to do from Router B to Router A
L2-Switch Configuration
interface GigabitEthernet0/1
description Back-to-Back MPLS Switches
switchport mode trunk
interface GigabitEthernet0/2
description **** CONNECTED TO VPN RTR - FA2/0  ****
switchport access vlan 202
switchport mode access
interface GigabitEthernet0/24
description **** CONNECTED TO CRTR1  1/7 ****
Router-A
interface FastEthernet2/0
no ip address
no ip redirects
n) ip unreachables
no ip proxy-arp
duplex auto
speed auto
interface FastEthernet2/0.202
encapsulation dot1Q 202
no cdp enable
standby 202 ip 200.200.200.20
standby 202 priority 120
standby 202 preempt
standby 202 name MPLS
Router-B(7609)
interface GigabitEthernet1/7
description **** CONNECTED TO MPLS SWITCH GI 0/24 ****
switchport
speed 1000
L3 Vlan
interface Vlan201
ip address 200.200.200.21 255.255.255.0
standby 202 ip 200.200.200.23
standby 202 preempt
L2 Vlan
Vlan 202
