05-25-2018 09:00 AM - edited 03-08-2019 03:08 PM
Hello.
When I run:
#debug tftp events TFTP Event debugging is on #debug tftp packets TFTP Packet debugging is on #debug ip dhcp server packet DHCP server packet debugging is on. #debug ip dhcp server events DHCP server event debugging is on. #debug ip dhcp sip all DHCP SIP all debugs debugging is on
I observe absolutely anything on the console.
I have not idea why. Can you please give me an idea how to investigate the reason why I cannot observe anything.
Thanks. BR.
05-25-2018 09:32 AM
Hi Leam2,
here replay massage is show normal as well debugging is also starting.
I think you are not shown any log on your terminal(via SSH/Telnet),because "no logging monitor/no logging trap" is configured.
you can check your debugging event/packet/log in "show log".
05-25-2018 09:49 AM - edited 05-28-2018 01:06 AM
Hello.
Thank you for your answer.
Below the output of "show log":
#show log
Syslog logging: enabled (0 messages dropped, 12 messages rate-limited, 3132 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 47137 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 24865 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 169 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (4096 bytes):
98: DHCPD: remote id 020a0000c0a804010100000a
May 25 16:25:07.198: DHCPD: interface = GigabitEthernet0/0/1.10
May 25 16:25:07.198: DHCPD: class id 436973636f2053797374656d732c20496e632e2049502050686f6e652043502d3838323100
May 25 16:25:07.198: DHCPD: FSM state change INVALID
Do you know how to increase the number of lines that we get when we run this command?
BR.
05-25-2018 10:58 AM
Hi Leam2,
you can increase buffer size using this command "logging buffered <buffer_size> ".
