Decrease speed on an Ethernet Interface
BjarneBoJensen
I have a WS3750G switch with a Gigabitinterface configured to speed 100Mb. How do I decrease this speed to only 20Mb (logical). I can't find any suitable solution for this.The reason for this is that the providers Foundry switch discards packets if more than 20Mb/sec is delivered to him.
Bjarne Bo Jensen +45 40304792
5 Replies 5
mahmoodmkl
Level 7
Level 7
u can use the rate-limit feature under the interface and specify the required bandwidth.
Mahmood
Hi Mahmood
Have just tested . It seems to work OK.
Thank you . Bjarne
Jon Marshall
Bjarne
The 3750 does not support egress policing but you can use the "srr-queue bandwidth limit" commmand to achieve what you want -
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_37_se/configuration/guide/swqos.html#wp1253412
Jon
Hi Jon
Have just tested the suggested solution. It seems to work perfect. Thank you . Bjarne
Bjarne
Glad to have helped.
Jon
