Default gateway and tracking
John Blakley
All,
I have a situation where I don't want a default gateway unless an interface is down. The default gateway is still getting put into the table even though I'm tracking based on this interface:
router# sh track
Track 1
Interface FastEthernet0/0 line-protocol
Line protocol is Up
1 change, last change 00:01:15
Delay up 20 secs, down 10 secs
Tracked by:
STATIC-IP-ROUTING 0
router# sh run | inc track
track 1 interface FastEthernet0/0 line-protocol
ip route 0.0.0.0 0.0.0.0 10.125.95.3 name Anira track 1
Is there a way of keeping a default route out of the table unless F0/0 goes down?
Thanks!
John
HTH, John *** Please rate all useful posts ***
xcz504d1114
Level 4
Level 4
If you're not monitoring the distant end's reachability, you can just use a floating static route.
I'm assuming you have a static route going out your fa0/0 when it is up, and it has the default AD of 1.
ip route 0.0.0.0 0.0.0.0 10.125.95.3 2
Both your solution and this solution only protect you if your interface actually goes down, it doesn't verify that the next hop going out of fa0/0 has NLRI. If you want to have that capability, you will need to setup IP SLA and track the SLA.
HTH,
Craig
Joe Clarke
Depending on the version of IOS, you could use the Embedded Event Manager to do this. For example, assuming 12.4(2)T or higher:
event manager applet add-default-route
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "ip route 0.0.0.0 0.0.0.0 10.125.95.3 name Anira"
action 4.0 cli command "end"
event manager applet no-default-route
event track 1 state up
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 10.125.95.3 name Anira"
