default Gateway For VLans
oosama123
hi everyone
this my first time here , hop everyone is doing fine :)
I'll try to be fast ,,, we have here 4 vlans ( vlan46 ,47,48,49) "" ip range = vlan name ""
and l3 switch 4500e (192.168.46.1,) , connected to fire ASA firewall (192.168.46.200)
Now , when any user from vlan 46 ping to firewall it's work fine. but any other vlan it's not pinging.
and the main problem here that we have a DMZ zone at 192.168.18.0,any user at 46 can log in and work , but user from other vlan cannt work
but , if i add this command to their PCs it will work : command prompt -->route add 192.168.18.0\24 192.168.48.200 (this from vlan 48 for ex.)
hope i made my self clean . English is not my first language :)
** already Add : ip route 0.0.0.0 192.168.46.200
and tried also  ip route 192.168.18.0\24 192.168.46.200
still when you do tracert 192.168.18.1 ,,,,
it will go to 192.168.48.1 then stuck
but if you do it from  vlan 46 :
192.168.46.1
192.168.16.1
enough talking :)
9 Replies 9
Wesoley
It appears that the firewall does not have a route to the 16 network. Therefore, verify that the firewall has a route statement to get to the 16 network. If not, add this to your ASA, route (inside interface name) 192.168.47.0 255.255.255.0 192.168.46.1
first of all thank you for your kind reply , second , am sorry by mistake i put 16 the correct one is 18 Now , when i try to add this command to my ASA it give me error : (config)# route inside1 192.168.18.0 255.255.255.0 192.168.46.1 ERROR: Cannot add route, connected route exists ** If you are in 46 subset everything work fine
I am sorry, that was my error. On the ASA, add these routes and you should be good.
route inside1 192.168.47.0 255.255.255.0 192.168.46.1
route inside1 192.168.48.0 255.255.255.0 192.168.46.1
route inside1 192.168.49.0 255.255.255.0 192.168.46.1
still with same error , sorry for late :
ciscoasa(config)# route inside 192.168.49.0 255.255.255.0 192.168.46.1
am trying on ASA,not on 4500 switch
Can you provide a snapshot of the route table on the ASA? Can you also provide a topology diagram? Where are the VLANs located?
sorry for late , our topology , all users connected to switch , then there's fiber cable to the core switch , and the core switch connected to ASA5100
:) i don't have diagram.
the problem now we install a printer server and the printers ip are in 46 subnet .
the user inside 48 cann't print.
Hello
So the ASA is performing the inter-vlan routing
Are these clients able reach their D/G, can they reach other vlans?
Can you post the ASA cfg?
res
Paul
Kind Regards
Paul
yes , ASA is performing the inter-vlan routing
and all user can ping each other inside subsets ( 48 , 49 , 46 )
but only users in 46 can reach  18.0
So i for example for user in 48 i need to put this command in command prompt so they can reach 18
Hello
First of all maybe vlan 46 is allowed ICMP, and the other vlans aren't,
Also I can see a default route pointing to the 192.168.48.200, So the addition of ip route 192.168.18.0 255.255.255.0 192.168.48.200 shouldn't be required
Has someone rightly stated previously does the ASA have routes back for the other subsets in your LAN
eg:
route Inside 192.168.6 255.255.255.0 192.168.48.xx ( ASA Lan facing next hop)
res
Paul
Kind Regards
Paul
