Default gateway question
Arcaneuk10
Dear all
a quick question, not sure if I am on the right track, here goes.
A system on your network is configured with the following address: 172.31.34.255/20. Which of the following should be configured as the default gateway in order to communicate with remote host assuming the router interface is the first in the subnet?
what I have done so far.
I calculated the subnet id, from above address which I make to be 172.31.32.0
and I calculted the broadcast address to be 172.31.16.255
Then I said the first usable ip address is 172.31.32.1 (add 1 in the last octet)
and the last usable address is 172.31.16.254 (minus 1 in the last octet)
so my range is 172.31.32.1 - 172.31.16.254
next I think i will want my default gateway will be the first usable number which is
172.31.32.1, is this right, or am I complicating the question. Grateful for some guidance regarding this.
regards
Arcaneuk
Hello
172.31.32.0/22 as already stated will give you 172.31.32.1 -172.31.47.254
As you have requested the D/G can be 172.31.32 1 - so the L3 interface for this subnet will have this ip address.
All you clients will have this ip as it D/G
Lasty 172.31.34.255 is a valid ip address and this can be used on any device attached to that subnet with the addressing below:
IP  =172.31.34.255
Subnet = 255.255.240.0
D/G = 172.31.32 1
res
Paul
Kind Regards
Paul
8 Replies 8
For a subnet with 172.31.34.255/20
you can have all the range below:
172.31.32.1 - 172.31.47.254
This means that the gateway can be any address between this range.
You can use a subnet calculator to confirm that.
H i Flavio
many thanks,for your reply, which subnet calculator do you use to confirm this?
regards
Arcaneuk
cheers, many thanks
saif musa
Level 9
Level 9
Please, find below...
*Which of the following should be configured as the default gateway= The IP address which you have already chosen to be your LAN network gateway address. e.g gateway address inside one of your LAN PCs.
*In order to communicate with remote host = You got to have a routing table inside your router to be able to communicate with remote hosts outside your network.
* Router interface is the first in the subnet = 172.32.31.1 255.255.240.0
many thanks Saif, thank you for your help.
regards
Arcaneuk
Hello
IP  =172.31.34.255
D/G = 172.31.32 1
res
Paul
Kind Regards
Paul
Hi Paul
Many thanks, very useful in helping me understand this.
Arcaneuk10
