Dhcp not working
luispereira75
Hi I have 2 sites connected with fiber and one i can get DHCP working for vlans the second site i can get DHCP for the main scopes but not for the vlans, Can anyone help?
23 Replies 23
we need more information. What is the DHCP server, the IOS device ? Post the configuations of the devices at both sites...
sounds like you might need ip helper on the vlan interfaces on 2nd site so it can reach the dhcp , just a guess though as you haven't provided any information
Site 1
Current configuration : 15796 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service password-encryption
service sequence-numbers
hostname SW-201-DataCenter
boot-start-marker
boot-end-marker
no aaa new-model
clock summer-time UTC recurring last Sun Mar 1:00 last Sun Oct 2:00
switch 1 provision ws-c3750g-24ts
switch 2 provision ws-c3750g-24ts
system mtu routing 1500
ip routing
no ip domain-lookup
interface Vlan1
no ip address
shutdown
interface Vlan5
description Telefones
ip address 172.19.68.250 255.255.252.0
interface Vlan8
description Informatica
ip address 192.168.8.250 255.255.255.0
interface Vlan10
ip address 172.19.67.250 255.255.252.0
interface Vlan50
ip address 192.168.50.250 255.255.255.0
interface Vlan100
ip address 192.168.100.250 255.255.255.0
interface Vlan150
ip address 192.168.150.250 255.255.255.0
interface Vlan201
ip address 192.168.201.250 255.255.255.0
interface Vlan202
ip address 192.168.202.250 255.255.255.0
no ip classless
ip route 0.0.0.0 0.0.0.0 172.19.67.254
luispereira75
Hi I have Ip helper address in the config but still not forwarding the DHCP.
no aaa new-model
switch 2 provision ws-c3750g-24ts-1u
ip routing
no ip domain-lookup
interface Vlan1
no ip address
interface Vlan5
no ip address
interface Vlan8
description Departamento IT
ip address 192.168.8.251 255.255.255.0
interface Vlan10
ip address 172.19.67.251 255.255.252.0
interface Vlan50
no ip address
interface Vlan100
ip address 192.168.100.251 255.255.255.0
interface Vlan150
description reparacoes eletronicas
no ip address
interface Vlan201
description producao
ip address 192.168.201.251 255.255.255.0
ip helper-address 172.19.64.19
interface Vlan202
ip address 192.168.202.251 255.255.255.0
ip default-gateway 172.19.67.254
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.100.250
ip http server
ip http authentication local
ip http secure-server
why do you have you 2 gateways , which is it 192 address or 172 ?
No i am forwarding to a layer 3 switch that is connected to the default gateway .
which platform/device is this ?
Try configuring:
ip forward-protocol nd
in global configuration mode...
also make sure dhcp service is on
(config)#service dhcp
try move the helper up to switch 1 , one of the vlans see if it makes a difference , really only need a vlan interface on the layer 3 switch , otherwise its just really for reachability in mgmt.
I don´t understand what you mean i have all vlans in both layer 3 switches and the datacenter is connected to the default gateway in the site 1, the site 2 is the second layer 3 swicth with not getting the dhcp.
The thing is: you are using the same address space at two different sites, as far as I can tell. Your DHCP server cannot service a remote site with the same address space as the local address space.
Am I totally off here ? Can you ping the DHCP server on site 1 from site 2, and vice versa ?
how are these sites connected ? You have configured a Vlan 10 interface at both sites, within the same address space. What is the link (layer 2 or layer 3) between the sites ?
They are connected with mono fiber and it is layer 2
shouldn't be using this on layer 2 switch ip route 0.0.0.0 0.0.0.0 192.168.100.250 , the default is enough
you don't need SVI interfaces then if its layer 2 and trunked up to site 1 which is layer 3 switch , they can be shut down but still remain at layer 2
