Default password is working with Tacacs+ switch
Hello all,
i`ve been facing some issues lately.
we use tacacs+ for our switches to authenticate and authorize. But we noticed that no matter username is, when we type password "cisco" we can log in to switch.
Anyone faced this issue before or know why it is like this?
login as: cisco
Using keyboard-interactive authentication.
password:
Password:
************************* WARNING MESSAGE *************************
* USE OF THIS SYSTEM IS RESTRICTED TO AUTHORISED USERS ONLY.      *
* UNAUTHORISED ACCESS OR USE IS PROHIBITED. YOU MUST HAVE         *
* EXPLICIT PERMISSION TO ACCESS THIS DEVICE. YOUR ACTIONS ON THIS *
* SYSTEM IS LOGGED AND VIOLATORS WILL BE PROSECUTED.              *
*                      AUTHORISED USE ONLY                        *
switch1>
5 Replies 5
cadet alain
Can you post your config.
Alain
Below is my configuration for log in:
aaa authentication login VTY-LOGIN group TACACS local-case enable
aaa authentication login CONSOLE group TACACS local-case none
aaa authentication enable default group TACACS enable line none
aaa authorization exec EXEC-AUTH group TACACS if-authenticated local none
aaa authorization commands 1 COMMANDS-1-AUTH group TACACS if-authenticated local none
aaa authorization commands 15 COMMANDS-15-AUTH group TACACS if-authenticated local none
aaa accounting exec EXEC-ACCOUNTING start-stop group TACACS
aaa accounting commands 1 COMMANDS-1-ACCT start-stop group TACACS
aaa accounting commands 15 COMMANDS-15-ACCT start-stop group TACACS
Can you perform debug aaa authentication while login and post output here.
Alain
I believe that the output of show tacacs might be helpful.
Rick
Rick
yes indeed you're right Richards and this was going to be my next request  after viewing the debug output.
Alain
