Default route problem
vinothlb1
Level 4
Level 4
If i have two 2 default routes in my router.. Whic route it will take?
andrew.prince
Level 11
Level 11
Depends on the weight - or you may even be load balancing.
I would suggest come failover:-
ip route 0.0.0.0 0.0.0.0 <>
ip route 0.0.0.0 0.0.0.0 <> 200
HTH>
