Default routing
kamalbora241
Hi All,
I have provided default routing at interfaces f0/0 and f0/1 of R1 with AD values as 1 and 2 (making f0/0 as primary route). Kindly advise if route for f0/1 will be installed as default route if interface f0/0 is down.
Also confirm where I can get additional information regarding the same.
Thanks in advance.
Julio E. Moisa
The default route will not be included into the routing table if the next hop is not reachable. So if fa0/0 is down you will have only the default route pointing to fa0/1 into the routing table.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
