Define MTU SIZE PER INTERFACE
silviorodrigues
Level 2
Level 2
Dear good morning!
Please help-me if this is possible on me4000.
I have Switch Me-3400 with IOS 122-55.SE3. I need set mtu size on int f0/1 for 1600 and mtu size f0/24 to 1998.
Can I do this?
As per the document It is possible.
But you need to try once.
Please rate the helpfull posts.
Naidu.
5 Replies 5
Latchum Naidu
Hi Silvio,
Configurable maximum transmission unit (MTU) of up to 9000 bytes, for bridging on Gigabit Ethernet ports, and up to 1998 bytes for bridging and routing on Fast Ethernet ports for Cisco ME 3400 Series Ethernet Access Switches.
Naidu.
But Can I Define different value on interface f0/1 to 1600 and f0/24 to 1998 ?
Naidu.
Whats document?
You can refer the following discussion.
https://supportforums.cisco.com/thread/247358
Naidu.
