Defining LAN and WAN From Different Angles or Perspectives
169.254.X.Y
Is it ture that defining a network as a LAN or WAN could be different from different perspectives or angles?
I'd say no.
 Local Area Network comprises protocols that you'll not see on WAN and vice-versa. The main function of LAN is deliver traffic over Layer 2 protocols where the payload is the IP packet.
 WAN in other hand deliver traffic over Layer 3 protocols and the payload is the data itself.
  You can mess this up saying that we can have Layer 2 as well on the WAN side but let's keep it straight.
 Dont we forget our CCNA books!!
Julio E. Moisa
LAN is basically a network used in a limited area, they are used to interconnect hosts.
WAN is a set of LAN's. A WAN is not limited by a building, basically a WAN is able to interconnnet networks through wide geographical networks. Also there are many type of WAN connections no used on LANs.
The following link could be useful:
http://www.ciscopress.com/articles/article.asp?p=2158215&seqNum=6
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
