Delayed Switch Commands
csterry23
Frequent Visitor
Frequent Visitor
Hello all,
After remotely connecting to a switch such as a 3850 is there a way to send time delayed commands?
I know a delayed reload can be issued to a switch, but what about other commands?
I want to shut an interface and no shut the interface after a delay such as 2 minutes, but let's say when the interface is shut the remote connection gets broken. Is there a way to send a time delayed command such as the no shut command to reopen the interface?
Alternatively, could it be done through a simple script such as a python script using sleep to delay the commands?
The script requires an event to launch, that is why we use a countdown timer, instead of say a syslog event.
As far as I know you cannot splice timers/ delays into the action steps, they complete as fast as possible. You can insert subscripts....it may not be what you have in mind!:
event manager applet noshut-interface
  event timer countdown time 300
  action 01 cli command "enable"
  action 02 cli command "config t"
  action 03 cli command "interface <your_interface>"
  action 04 cli command "no shut"
  action 05 cli command "event manager applet sub-script"
  action 06 cli command "event timer countdown time 300"
  action 07 cli command "action 1.0 cli command enable"
  action 08 cli command "action 2.0 cli config t"
  action 09 cli command "action 3.0 xxxxxxx"
  action 10 cli command "action 4.0 end"
  action 11 cli command "end"
There was a EEM script board on this forum, but it has now vanished. I think it has been rolled into 'network management'. There is a cisco chap @Joe Clarke who is the definition of an EEM expert who roams that board. Maybe put a follow-up post there regarding a inter-step delay.
cheers,
Seb.
Seb Rupik
Hi there,
Create an EEM script and use the a countdown timer:
  action 001 cli command "enable"
  action 002 cli command "config t"
  action 003 cli command "interface <your_interface>"
  action 004 cli command "no shut"
  action 005 cli command "end"
...run it with the command:
event manager run noshut-interface
You can tweak the script so that it detects certain events prior to running, ie and interface being down/down, connectivity being lost.
cheers,
Seb.
Thank you the quick reply, Seb.
I'm assuming the event timer can be moved/added to different lines/steps in the EEM script to put pauses between commands, correct?
cheers,
Seb.
