06-23-2022 10:21 PM
Good Day,
Trust everyone is well
My question is regarding if you have a network created with devices and then you need to delete that same network and re add it later on using the same devices will you need to reconfigure the devices or will they just be able to join the network again with zero touch? My network is a static IP address and we are not doing DCHP.
Solved! Go to Solution.
06-23-2022 10:47 PM
Good morning @stephen.davie
This does work. The devices will be re-added as previously configured. Just as long as you’re not adding them to a different Org or Network.
06-23-2022 10:47 PM
