Deleting CRASH INFO from Flash memory on Cisco 2950
M Talha
Dear ALL,
Well i am encountering a problem where i am unable to save my modified configuration because there isn't enough space in my flash memory on CISCO 2950 switch. The crash info file has taken up 72355 bytes of space in flash memory. My question is that how can i delete this file so i can free up space on my 2950 switch. Please share the command to delete this file.
Talha
Leo Laohoo
Command:  delete /force /recur flash:<CRASH FILES>
Thanks Leo :)
Sorry, In may case this command is not helpful. Can you please refer any other way.
Badar
 - In your picture the files are marked as deleted, what if you issue dir flash:
 M.
