Deleting vlan Database on 6500 running IOS
anjery1234
Trying to delete the vlan database on a 6500 running IOS.
Please help.
Jeremy
Hi:
do a "dir all-files"
Find the directory where the vlan.dat file is found and delete it.
example:
del nvram:vlan.dat
8 Replies 8
Jon Marshall
Jeremy
erase const_nvram:/vlan.dat
Jon
Jon,
Not sure what I'm doing wrong.
All appeared fine but the command won't work. The code I'm running is s72033-ipservicesk9-mz.122-18.SXF5.bin
bkbb-rp01#erase const_nvram:/vlan.dat
% Invalid input detected at '^' marker.
bkbb-rp01#dir con
bkbb-rp01#dir const_nvram:
Directory of const_nvram:/
1 -rw- 0 vlan.dat
129004 bytes total (129004 bytes free)
Hi:
example:
del nvram:vlan.dat
Jeremy
Just try
6500# erase const_nvram:
If that doesn't work
6500# erase ?
do you get the option to erase the const_nvram: ?
Jon
delete const_nvram:/vlan.dat
Use the above command for removing vlan database.
Jon,
This first command was the good one.
I just needed to set my vtp mode to server.
Thanks a lot
Dipesh Patel
Level 2
Level 2
You can delete it from
const_nvram:vlan.dat
Deepesh
Thanks a lot.
