Port-based vlan in Cisco 2960 series
prashanma
Hi Team,
Do Cisco 2960XR supported Port based vlan ?
Francesco Molino
I believe you want to protect communication between hosts on each port of the switch. An i right?
This feature is called private vlan and it's supported on your platform.
Here is the documentation:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960xr/software/15-0_2_EX1/vlan/configuration_guide/b_vlan_152ex1_2960-xr_cg/b_vlan_152ex1_2960-xr_cg_chapter_0101.html#ID231
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
