design
ohassairi
Level 5
Level 5
hello
when using cisco nexus 7000 with VDC as an aggregation and core , what should be the link between aggregation and core: L2 or L3?
what is the better choise?
kyukim
It depends on your network requirement, budget and business goals.
In general data center's 3 Tier design (Core/Agg/Access), L3 connection is recommended between CORE and Agg layers.
Below is typical 3 Tier Design requirement.
-Core Layer:
Modular Chassis
High 10GE Density
Low Oversubscription
Layer 3 Links to Aggregation
Hand-off to Campus
- Aggregation Layer:
Modular Chassis
High 10GE Density
Layer 2 Trunks to Access
Default Gateway for Servers (L2/L3 boundary)
Typically Attaches Services
- Access Layer:
Top of Rack (ToR)
End/Middle of Row (EoR/MoR)
GE or 10GE to Servers
Layer 2 Switching
Layer
Switch Type
Port Speed
Config
Other
Core
Modular
10GE
Layer 3
Campus hand off
Aggregation
Modular
10GE
Layer 2/3 boundary
Services (optional)
Access
Fixed or Modular
GE/10GE
Layer 2
ToR or MoR
Also, you can use 2 Tier design by combing Core & Agg.
Cisco usually recommend 3 Tier design if you want to have a building block kind of approach to design as you need something to interconnect all those building blocks.
If one building block is enough to satisfy the needs of the network, then you can collapse essentially the core and aggregation into a single layer
You can see more detail from CISCO Datacenter 3.0 IP Infra document.
Hope this helps.
KK...
kyukim
-Core Layer:
Modular Chassis
High 10GE Density
Hand-off to Campus
Modular Chassis
High 10GE Density
- Access Layer:
Top of Rack (ToR)
Layer 2 Switching
Layer
Switch Type
Port Speed
Config
Other
Core
Modular
10GE
Layer 3
Campus hand off
Aggregation
Modular
10GE
Layer 2/3 boundary
Services (optional)
Access
Fixed or Modular
GE/10GE
Layer 2
ToR or MoR
Hope this helps.
KK...
kyukim
-Core Layer:
Modular Chassis
High 10GE Density
Hand-off to Campus
Modular Chassis
High 10GE Density
- Access Layer:
Top of Rack (ToR)
Layer 2 Switching
Layer
Switch Type
Port Speed
Config
Other
Core
Modular
10GE
Layer 3
Campus hand off
Aggregation
Modular
10GE
Layer 2/3 boundary
Services (optional)
Access
Fixed or Modular
GE/10GE
Layer 2
ToR or MoR
Hope this helps.
KK...
