Designging core switch
drnteam
Can any one help on this, if the network consists of 2 core switches and 10+ distribution switch, is it feasible to configure the VLANs in distribution switch. Whcih is the best config to do when designing a VLAN.
Is it good to keep the VLANs under core switch or distribution switch.
cisco_lad2004
Level 5
Level 5
Not knowing ur full requirement, I will give a generic response.
I usually try to seperate VLANs from access to cross to core. so, I use access vlans on access switches , then route back to core switch on over one uplink VLAN.
Sam
That means no vlans are entering into core switch. In that case where can we run the HSRP.
Are u planning in terminating ur vlans on access switches. what I have in mind is :
ACC_SW01==CUST==ACCSW02, all on same VLAN, then you can run HSRP on access switches.
Please add more info on your requirement, so we can help you better.
Sam
