Destination Host Unreachable in Packet Tracer
I can't ping the other PCs, what seems to be the problem
That password for routers and switches is "casem"
Martin L
there are no routes on routers at all; either add static routes or enable routing protocol.
Regards, ML
**Please Rate All Helpful Responses **
** We could solve this for you but then you will not learn anything; what's purpose in that?
***if this is a PT lab, you can attach PT file here but it must be in zip format. ***
