Destination host unreachable
Rohman ID
I am having a DNS server ping problem, when I try to ping the DNS server the result is that the destination host unreachable. I think I have a problem in the router but I don't know where it went wrong please help me
Config GW in dns serve
MHM
M02@rt37
Hello @Rohman ID,
On your diagram you write "static routes"
But there are no static routes on Routers !!!! Configure them on each router
Under configuration terminal, add ip route <destination subnet> <mask> <Next hop> command
Best regards
