How to Configure Connection SFP+
AnandaHaidar
Hello
I need your help, how to configure this. In the CLI, SFP+ has been detected. Now, how to connect beetween switch? or what command should i enter in CLI?
Because it's still down, on the indicator light or port status on the CLI.Screenshot 2023-12-12 231413.png
15 Replies 15
Mark Elsen
        - Foreign SFP's are not guaranteed to work , for Cisco compatibility check : https://tmgmatrix.cisco.com/
 M.
balaji.bandi
There is no configuration required for the port to come uop ( as long as interface have no shutdown command)
1. make sure SFP detected on the port
2. if you using 10GB SFP ports, setup and speed and speed  no negotiation on the port)
Once the Physical port up
then you decide what you like to between the switches, port should be Trunk/ Access port or Layer 3 Interface. (based on the decision the port configuration can be advised)
checking :
1. show interface x/x (show you the interface detected or not) post that output from both the swithes here.
2. post show run interface x/x  (from both the switches?)
BB
M02@rt37
Hello @AnandaHaidar
please share output of the command
#show interface ×/× transceiver
x/x interface where SFP+ is inserted.
Thanks.
Best regards
Can I see show interface status
MHM
ok what is the distance between these switches, have Looked at the port, do you see Light ?
Try to twist RX and TX and test it, or give loop and see is the port come up ?
BB
AnandaHaidar
@AnandaHaidar
Thanks or the output
On the other switch you are in full 10G also ? please sh int status of the other switch.
Best regards
The other switch is same. Full 10G.
Thanks @AnandaHaidar
Reverse one of the two strands of the fiber.
Tell us if it is good.
Best regards
Still not able
The show interface status show no a-full so autonego is disable in this interface.
The autonego can not work in some SFP that make issue.
If one side no support autonego you need them to disable autonego and hardcoded speed and duplex in other side
Hope this what you face here
Goodluck
MHM
command for IOS XE :
no speed nonegotiate
BB
