Destination NAT from outside segment
achrich
We have a router which connects 2 sites however for various reason the inside/outside are back to front in logical terms.
There is now a requirement to perform a static destination NAT however this needs to happen on the outside NAT segment.
Is this possible without reconfiguring all the NAT or should I consider a PBR ( not a CPU intensive router )
Any pointers would be helpful.
Jon Marshall
Andrew
It may be easier to help you if you could
1) draw a quick layout of the router connections
2) give some ip addresses as examples of what you need.
Jon
hi - thanks for the reply. Managed to figure it out in the end.
