Device not getting ip adddress
susim
Level 3
Level 3
Some particular devices ( android os ) is not getting ip address from  dhcp server. But windows clients are getting the ip address.
How can i troubleshoot this issue , anything need to be done on the access ports
10 Replies 10
I'm assuming wireless right?
Which model of Access point are you using?
Please also check the Frequency your AP is using and if the Android devices supports it.
http://glassonionblog.wordpress.com/2008/08/04/wireless-protocols-ieee-80211-a-b-g-n-compared/
it is wired
What kind of device is the server?
If a Cisco router run
debug ip dhcp packet
If it's not a network device per se but a dedicated server then captures are your way to go
-Run wireshark at the client level
If that does not provide the answer use a SPAN session at the switch level
Jcarvaja
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
the wireshark trace file attached ,
I dont understand why  vlan interface from both switches (hsrp )  has to  'offer  DHCP '
it is an issue or normal
Hello
Can you post the config of the switches that supply DHCP?
res
Paul
Kind Regards
Paul
Hi paul here is the  vlan configuration
192.168.8.11 is windows dhcp server
interface Vlan58
 ip address 10.0.58.2 255.255.255.0
 ip helper-address 192.168.8.11
 standby 58 ip 10.0.58.1
 standby 58 priority 200
 standby 58 preempt
interface Vlan58
 standby 58 preempt
So I can see you have a DHCP server at 192.168.8.11, is that the DHCP Server we are using?
For that please add on both devices:
interface Vlan58
standby 58 HSRP1
 ip helper-address 192.168.8.11 redundancy  HSRP1
Now if the switch is the DHCP server, make sure you split the DHCP pools on each box as they do not share the DHCP binding table, you do not want to be providing the same IP addresses on both routers,
Does it make sense?
Please let us know whether the switch is the one that should give it or that other server?
Julio Carvajal
The server is offering  the dhcp service not the switch .
Then Go ahead with my approach:
interface Vlan58
standby 58 HSRP1
Julio Carvajal
Hi julio
Thanks for your great suggestion . I want to add something before i change .
The thing is  if the device got ip address from dhcp  after few hours ,lets  say the switch went down for short period of time . In this case  all the devices should retain the ip addresses ?
