devices not able to connect to network
HUGH LANCASTER
Cisco 3750 swtiches. Core switch has ip routing enabled.
I have a couple of sorenson VRS devices that cannot connect to the network. At first I thought it was a dhcp issue. I gave it a static IP address and still no go. Thinking it was port security issue, I disabled port security on the switch completed a shutdown interface and no shutdown command. Still no go. From the same port, I can connect a laptop and a ip address is assigned. No issues. Any suggestions would be appreciated. Thanks
34 Replies 34
Thanks for the debug output. But we need some context to be able to interpret the output. What address is the 3750 switch and what address is the VRS device?
Rick
Rick
10.100.0.5 switch
10.100.1.245 VRS (DHCP)
Thanks for the debug information. I am surprised that I do not see any arp activity in the debug that has either 10.100.0.5 or 10.100.1.245.
Would you post the configuration of interface vlan 1?
Rick
Rick
Switch that is connected to VRS device:
interface Vlan1
ip address 10.100.0.5 255.255.248.0
no ip proxy-arp
no ip route-cache
no ip mroute-cache
Thank you for the interface configuration. It does verify that the vlan/subnet should include both addresses. So I am puzzled why the debug does not show any traffic to or from the switch and no traffic to or from the VRS device.
Rick
Rick
Here is the debug arp from Switch 10.100.0.4 (IP route enabled)>>> Switch 10.100.0.5 (VRS connected to this switch) connects to this switch.
Log Buffer (4096 bytes):
9f.5287, dst 10.100.8.38 001d.a271.9541, interface Vlan5
603054: 28w2d: IP ARP: rcvd req src 10.100.0.254 0000.947e.0000, dst 10.100.0.21 Vlan1
603055: 28w2d: IP ARP: rcvd req src 10.100.0.21 000a00000000b, dst 10.100.0.254 Vlan1
603056: 28w2d: IP ARP: rcvd req src 10.100.0.254 0000.947e.0000, dst 10.100.0.4 Vlan1
603057: 28w2d: IP ARP: sent rep src 10.100.0.4 cb1d.a271.0000,
                 dst 10.100.0.254 0000.947e.0000 Vlan1
603058: 28w2d: IP ARP: rcvd req src 10.100.1.97 6400.6a3c.7206, dst 10.100.1.205 Vlan1
603059: 28w2d: IP ARP: rcvd req src 10.100.0.21 000a00000000b, dst 10.100.0.186 Vlan1
603060: 28w2d: IP ARP: rcvd req src 10.100.0.119 6400.6a6a.f328, dst 10.100.0.4 Vlan1
603061: 28w2d: IP ARP: sent rep src 10.100.0.4 cb1d.a271.0000,
                 dst 10.100.0.119 6400.6a6a.f328 Vlan1
603062: 28w2d: IP ARP: rcvd req src 10.100.1.141 cc44.63f2.aa24, dst 10.100.0.4 Vlan1
603063: 28w2d: IP ARP: sent rep src 10.100.0.4 cb1d.a271.0000,
                 dst 10.100.1.141 cc44.63f2.aa24 Vlan1
603064: 28w2d: IP ARP: rcvd req src 10.100.8.1 000007f9f0000, dst 10.100.8.38 Vlan5
603065: 28w2d: IP ARP: ignored gratuitous arp src 10.100.8.1 000007f9f0000, dst 10.100.8.38 001d.a271.9541, interface Vlan5
603066: 28w2d: IP ARP: rcvd req src 10.100.0.21 000a00000000b, dst 10.100.1.136 Vlan1
603067: 28w2d: IP ARP: rcvd req src 10.100.0.15 000a00000000a,, dst 10.100.0.254 Vlan1
603068: 28w2d: IP ARP: rcvd req src 10.100.0.254 0000.947e.0000, dst 10.100.0.15 Vlan1
603069: 28w2d: IP ARP: rcvd req src 10.100.0.16 0000.5d01.5000, dst 10.100.1.188 Vlan1
603070: 28w2d: IP ARP: rcvd req src 10.100.0.21 000a00000000b, dst 10.100.0.75 Vlan1
603071: 28w2d: IP ARP: rcvd req src 10.100.8.1 000007f9f0000, dst 10.100.8.38 Vlan5
603072: 28w2d: IP ARP: ignored gratuitous arp src 10.100.8.1 000007f9f0000, dst 10.100.8.38 001d.a271.9541, interface Vlan5
603073: 28w2d: IP ARP: rcvd req src 10.100.0.220 80e6.5078.b5c8, dst 10.100.0.4 Vlan1
603074: 28w2d: IP ARP: sent rep src 10.100.0.4 cb1d.a271.0000,
                 dst 10.100.0.220 80e6.5078.b5c8 Vlan1
603075: 28w2d: IP ARP: rcvd req src 10.100.1.60 6c29.95cb.c11d, dst 10.100.0.4 Vlan1
603076: 28w2d: IP ARP: sent rep src 10.100.0.4 cb1d.a271.0000,
                 dst 10.100.1.60 6c29.95cb.c11d Vlan1
603077: 28w2d: IP ARP: rcvd rep src 10.100.0.36 1cdf.0f2f.3006, dst 10.100.0.36 Vlan1
603078: 28w2d: IP ARP: rcvd req src 10.100.1.173 e8b1.fc25.c448, dst 10.100.0.4 Vlan1
603079: 28w2d: IP ARP: sent rep src 10.100.0.4 cb1d.a271.0000,
                 dst 10.100.1.173 e8b1.fc25.c448 Vlan1
603080: 28w2d: IP ARP: rcvd req src 10.100.0.21 000a00000000b, dst 10.100.0.75 Vlan1
603081: 28w2d: IP ARP: rcvd rep src 10.100.0.198 001f.9e1d.5fbc, dst 10.100.0.198 Vlan1
603082: 28w2d: IP ARP: ignored gratuitous arp src 10.100.0.198 001f.9e1d.5fbc, dst 10.100.0.198 cb1d.a271.0000, interface Vlan1
603083: 28w2d: IP ARP: rcvd req src 10.100.8.1 000007f9f0000, dst 10.100.8.38 Vlan5
603084: 28w2d: IP ARP: ignored gratuitous arp src 10.100.8.1 000007f9f0000, dst 10.100.8.38 001d.a271.9541, interface Vlan5
603085: 28w2d: IP ARP: rcvd req src 10.100.0.21 000a00000000b, dst 10.100.0.75 Vlan1
603086: 28w2d: IP ARP: rcvd req src 10.100.0.21 000a00000000b, dst 10.100.0.24 Vlan1
603087: 28w2d: IP ARP: rcvd req src 10.100.0.21 000a00000000b, dst 10.100.1.209 Vlan1
603088: 28w2d: IP ARP: rcvd req src 10.100.1.243 1093.e95e.a022, dst 10.100.0.4 Vlan1
603089: 28w2d: IP ARP: sent rep src 10.100.0.4 cb1d.a271.0000,
                 dst 10.100.1.243 1093.e95e.a022 Vlan1
603090: 28w2d: IP ARP: rcvd req src 10.100.0.15 000a00000000a,, dst 10.100.1.154 Vlan1
603091: 28w2d: IP ARP: rcvd rep src 10.100.0.5 00000c390.0000, dst 10.100.0.5 Vlan1
603092: 28w2d: IP ARP: rcvd req src 10.100.8.1 000007f9f0000, dst 10.100.8.38 Vlan5
603093: 28w2d: IP ARP: ignored gratuitous arp src 10.100.8.1 000007f9f0000, dst 10.100.8.38 001d.a271.9541, interface Vlan5
603094: 28w2d: IP ARP: rcvd rep src 10.100.0.108 1cdf.0f2f.302c, dst 10.100.0.108 Vlan1
603095: 28w2d: IP ARP: rcvd req src 10.100.0.1 0000.7f9f.0000, dst 10.100.1.238 Vlan1
Like I said before, I can connect a laptop to the same port and no issues- dhcp or static.
I appreciate that you have sent me two sets of debug output. But neither of them is showing what we need to see. I suspect that you did not fully understand what I was asking for when I asked "try to ping the VRS from the device where its default gateway is."  So let me try again:
- what is the default gateway for the VRS device at IP 10.100.1.245? (and while I am asking what is the subnet mask used for that device)
- what device is that default gateway IP located on?
- on that device please enable debug arp and then attempt to ping 10.100.1.245
- post the debug output
Rick
Rick
default gateway 10.100.0.4
255.255.248.0
From the 10.100.0.4 (ip routing enable) I cannot ping the device.
I am puzzled why the debug that you sent previously does not have an attempt to arp for the VRS device. So perhaps we should look for a different approach to this problem. In reading back through this thread there seem to be a couple of places where you say that if you connect a laptop to this access port where VRS is connected that the laptop works fine (is able to access Internet resources, responds to ping, etc). Can you confirm that this is the case?
If so then it would seem that this problem has something to do with the VRS device and not so much the configuration of the switches. Do you have other VRS devices installed that do respond to ping?
Is there perhaps some way to verify operation of the VRS device other than trying to ping it?
Rick
Rick
It is crazy. Yes, I can connect laptop to same port and hit internet resources, ping, etc. I have an older NVP1 that I connect to same port, I can ping and hit internet resources. Remove device, connect Sorenson tech took the VP (VRS) home, reset to factor defaults, works!
Are you saying that after reset to factory defaults that the VRS does work?
Rick
Rick
No. It works at home but not here.
That is unexpected. So it seems to point to something in your network environment. Can you post the configuration of both 3750, and identify the port where VRS  is connected, and the ports where the switches connect?
Rick
Rick
firewall: trusted interface 10.100.0.1 >>>  connects to 10.100.0.3>>>10.100.0.4( ip routing) (Star- all switches connect to this switch GBIC, all trunk>>>>>Switch: 10.100.0.5 >> connects to port
Interface VP is connect to is  on 10.100.0.5 >>>fa/0/25
Config for 10.100.0.4:
Building configuration...
Current configuration : 16323 bytes
! Last configuration change at 11:01:41 CST Tue Mar 7 2017 by admin
! NVRAM config last updated at 11:01:35 CST Tue Mar 7 2017 by admin
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service password-encryption
service sequence-numbers
hostname Massey
boot-start-marker
boot-end-marker
username admin privilege 15 password 7 022E0B4905031B321F0758
aaa new-model
aaa session-id common
clock timezone CST -5
clock summer-time CDT recurring
switch 1 provision ws-c3750g-12s
switch 2 provision ws-c3750-48p
system mtu routing 1500
vtp domain ENCSD_CORE
vtp mode transparent
ip subnet-zero
ip routing
ip domain-name encsd.net
ip dhcp relay information policy keep
ip dhcp relay information trust-all
c
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
spanning-tree vlan 1 priority 4096
vlan internal allocation policy ascending
vlan 5
 name Guest_Vlan
vlan 10
 name Cameras
vlan 20
 name Admin
vlan 30
 name HR
vlan 40
 name Dorm
vlan 50
 name Maint
interface GigabitEthernet1/0/1
 switchport mode trunk
 auto qos voip trust
 macro description cisco-switch
 spanning-tree link-type point-to-point
interface GigabitEthernet1/0/2
 auto qos voip trust
interface GigabitEthernet1/0/3
 auto qos voip trust
interface GigabitEthernet1/0/4
 auto qos voip trust
interface GigabitEthernet1/0/5
 auto qos voip trust
interface GigabitEthernet1/0/6
 auto qos voip trust
interface GigabitEthernet1/0/7
 auto qos voip trust
interface GigabitEthernet1/0/8
 auto qos voip trust
interface GigabitEthernet1/0/9
 auto qos voip trust
interface GigabitEthernet1/0/10
 auto qos voip trust
interface GigabitEthernet1/0/11
 description connects to Alford
 auto qos voip trust
interface GigabitEthernet1/0/12
 auto qos voip trust
interface FastEthernet2/0/1
 description connected to Eagles 2960 gi0/1
 switchport mode access
 storm-control broadcast level 10.00
 macro description cisco-desktop
 spanning-tree portfast
 spanning-tree bpduguard enable
interface FastEthernet2/0/2
interface FastEthernet2/0/3
interface FastEthernet2/0/4
interface FastEthernet2/0/5
interface FastEthernet2/0/6
interface FastEthernet2/0/7
interface FastEthernet2/0/8
interface FastEthernet2/0/9
interface FastEthernet2/0/10
interface FastEthernet2/0/11
interface FastEthernet2/0/12
interface FastEthernet2/0/13
 description Massey DwnSt Hallway next game room 19
 switchport access vlan 10
 switchport nonegotiate
interface FastEthernet2/0/14
interface FastEthernet2/0/15
interface FastEthernet2/0/16
interface FastEthernet2/0/17
 description Massey Lounge TV B1
interface FastEthernet2/0/18
interface FastEthernet2/0/19
interface FastEthernet2/0/20
interface FastEthernet2/0/21
interface FastEthernet2/0/22
interface FastEthernet2/0/23
interface FastEthernet2/0/24
interface FastEthernet2/0/25
interface FastEthernet2/0/26
interface FastEthernet2/0/27
interface FastEthernet2/0/28
interface FastEthernet2/0/29
interface FastEthernet2/0/30
 description Massey Lobby VRS
interface FastEthernet2/0/31
interface FastEthernet2/0/32
interface FastEthernet2/0/33
interface FastEthernet2/0/34
 description Cisco 1642 AP Massey Cafe
interface FastEthernet2/0/35
 description Massey Library Upstairs 18
interface FastEthernet2/0/36
 description none
interface FastEthernet2/0/37
interface FastEthernet2/0/38
interface FastEthernet2/0/39
interface FastEthernet2/0/40
interface FastEthernet2/0/41
 description Cisco AP 1642 Massey Lobby
interface FastEthernet2/0/42
 description Massey Gate Entrance
interface FastEthernet2/0/43
interface FastEthernet2/0/44
interface FastEthernet2/0/45
 description Massey dwnst lobby cantene 19
interface FastEthernet2/0/46
interface FastEthernet2/0/47
interface FastEthernet2/0/48
interface GigabitEthernet2/0/1
 auto qos voip trust
interface GigabitEthernet2/0/2
 auto qos voip trust
interface GigabitEthernet2/0/3
 description connects to vestal
 auto qos voip trust
interface GigabitEthernet2/0/4
 auto qos voip trust
interface Vlan1
 ip address 10.100.0.4 255.255.248.0
 ip helper-address 10.100.0.21
 no ip proxy-arp
interface Vlan5
 ip address 10.100.8.2 255.255.248.0
 no ip proxy-arp
interface Vlan10
 ip address 10.100.16.2 255.255.248.0
interface Vlan20
 ip address 10.100.24.1 255.255.248.0
interface Vlan30
 ip address 10.100.32.1 255.255.248.0
interface Vlan40
 ip address 10.100.48.1 255.255.248.0
interface Vlan50
 ip address 10.100.56.1 255.255.248.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.100.0.1
ip http server
ip http secure-server
snmp-server community public RO
snmp-server host 10.100.0.119 public
control-plane
ntp clock-period 36028942
ntp server 131.107.13.100
ntp server 10.100.0.15
ntp server 10.100.0.119
ntp server 128.109.42.114
mac address-table notification mac-move
end
**********switch: 10.100.0.5*********
Current configuration : 71480 bytes
! No configuration change since last restart
version 12.2
no service pad
hostname Woodard3750
boot-start-marker
boot-end-marker
 --More--         macro global description cisco-global | cisco-global
aaa new-model
switch 1 provision ws-c3750-48p
switch 3 provision ws-c3750-48p
switch 4 provision ws-c3750-48p
switch 5 provision ws-c3750-48p
udld aggressive
ip name-server 10.100.0.21
 --More--         mls qos map cos-dscp 0 8 16 26 32 46 46 56
crypto pki trustpoint TP-self-signed-3281052288
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3281052288
 revocation-check none
 rsakeypair TP-self-signed-3281052288
auto qos srnd4
errdisable recovery cause bpduguard
errdisable recovery cause link-flap
errdisable recovery interval 60
spanning-tree mode rapid-pvst
spanning-tree loopguard default
vlan 5
 --More--          name Guest_Vlan
vlan 10
 name Cameras
vlan 20
 name admin
vlan 30
 name HR
vlan 40
 name dorm
vlan 50
 name Maint
interface FastEthernet1/0/1
 switchport port-security aging time 2
 switchport port-security violation restrict
 --More--          switchport port-security aging type inactivity
interface FastEthernet1/0/2
interface FastEthernet1/0/3
 --More--          spanning-tree portfast
interface FastEthernet1/0/4
interface FastEthernet1/0/5
 description Wireless_EI
 --More--         !
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
 --More--          switchport port-security aging time 2
interface FastEthernet1/0/9
interface FastEthernet1/0/10
 switchport access vlan 5
interface FastEthernet1/0/11
interface FastEthernet1/0/12
 spanning-tree portfast disable
 --More--         interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
 description Wireless Controller WLC2
 --More--          switchport trunk allowed vlan 1,5
interface FastEthernet1/0/16
interface FastEthernet1/0/17
 --More--          macro description cisco-desktop
interface FastEthernet1/0/18
interface FastEthernet1/0/19
 --More--         !
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
interface FastEthernet1/0/24
 --More--          storm-control broadcast level 10.00
interface FastEthernet1/0/25
interface FastEthernet1/0/26
 --More--          spanning-tree bpduguard enable
interface FastEthernet1/0/27
interface FastEthernet1/0/28
interface FastEthernet1/0/29
 --More--          switchport mode access
interface FastEthernet1/0/30
interface FastEthernet1/0/31
interface FastEthernet1/0/32
interface FastEthernet1/0/33
interface FastEthernet1/0/34
interface FastEthernet1/0/35
 --More--         interface FastEthernet1/0/36
interface FastEthernet1/0/37
interface FastEthernet1/0/38
 --More--          switchport port-security violation restrict
interface FastEthernet1/0/39
interface FastEthernet1/0/40
interface FastEthernet1/0/41
interface FastEthernet1/0/42
 --More--         !
interface FastEthernet1/0/43
interface FastEthernet1/0/44
interface FastEthernet1/0/45
interface FastEthernet1/0/46
interface FastEthernet1/0/47
interface FastEthernet1/0/48
 spanning-tree bpduguard disable
 auto qos trust
 storm-control broadcast level 87.00 65.00
 storm-control unicast level 87.00 65.00
 macro description cisco-switch | cisco switch
 --More--         !
 auto qos trust
 auto qos trust
 auto qos trust
 --More--          storm-control broadcast level 87.00 65.00
 description Hrdsd06
 macro description cisco-desktop | cisco-desktop
 --More--         !
 description TAC
 --More--         interface FastEthernet2/0/7
 description Tac2
 description snap
 speed 100
 duplex full
 description ENCSD3
 description Renlearn
 --More--         !
 description Wire_Control
 --More--          switchport mode trunk
 description ENCSD1
 description Moodle
 description Internet
 --More--         interface FastEthernet2/0/23
 description Server encsd1
 --More--          speed 100
 duplex full
 --More--         !
 --More--         !
 auto qos trust
 auto qos trust
 auto qos trust
 --More--          macro description cisco-switch
 auto qos trust
interface FastEthernet3/0/1
interface FastEthernet3/0/2
 --More--         interface FastEthernet3/0/3
interface FastEthernet3/0/4
interface FastEthernet3/0/5
interface FastEthernet3/0/6
interface FastEthernet3/0/7
interface FastEthernet3/0/8
interface FastEthernet3/0/9
interface FastEthernet3/0/10
interface FastEthernet3/0/11
interface FastEthernet3/0/12
interface FastEthernet3/0/13
interface FastEthernet3/0/14
interface FastEthernet3/0/15
interface FastEthernet3/0/16
interface FastEthernet3/0/17
interface FastEthernet3/0/18
interface FastEthernet3/0/19
interface FastEthernet3/0/20
 --More--         !
interface FastEthernet3/0/21
interface FastEthernet3/0/22
interface FastEthernet3/0/23
interface FastEthernet3/0/24
interface FastEthernet3/0/25
 --More--         interface FastEthernet3/0/26
interface FastEthernet3/0/27
interface FastEthernet3/0/28
interface FastEthernet3/0/29
interface FastEthernet3/0/30
interface FastEthernet3/0/31
interface FastEthernet3/0/32
interface FastEthernet3/0/33
interface FastEthernet3/0/34
interface FastEthernet3/0/35
interface FastEthernet3/0/36
interface FastEthernet3/0/37
interface FastEthernet3/0/38
interface FastEthernet3/0/39
interface FastEthernet3/0/40
interface FastEthernet3/0/41
interface FastEthernet3/0/42
interface FastEthernet3/0/43
 --More--         !
interface FastEthernet3/0/44
interface FastEthernet3/0/45
interface FastEthernet3/0/46
interface FastEthernet3/0/47
interface FastEthernet3/0/48
 --More--         interface GigabitEthernet3/0/1
 srr-queue bandwidth share 10 10 60 20
 queue-set 2
 priority-queue out
 mls qos trust cos
 auto qos trust
 macro description cisco switch
interface GigabitEthernet3/0/2
 queue-set 2
 priority-queue out
 mls qos trust cos
 auto qos trust
 --More--          spanning-tree link-type point-to-point
interface GigabitEthernet3/0/3
 queue-set 2
 priority-queue out
 mls qos trust cos
 auto qos trust
 macro description cisco system
interface GigabitEthernet3/0/4
 queue-set 2
 priority-queue out
 mls qos trust cos
 auto qos trust
interface FastEthernet4/0/1
 description internet
interface FastEthernet4/0/2
interface FastEthernet4/0/3
 description ENCSD3
 macro description cisco-desktop | cisco-desktop | cisco-desktop | cisco-desktop
interface FastEthernet4/0/4
 description Business office Jean Craft
interface FastEthernet4/0/5
 --More--          description ENCSD5
interface FastEthernet4/0/6
 description encsd6v
interface FastEthernet4/0/7
 description TAC
interface FastEthernet4/0/8
interface FastEthernet4/0/9
 description MacServer
 speed 100
 duplex full
 --More--         !
interface FastEthernet4/0/10
interface FastEthernet4/0/11
 description Wood Upstairs Hall of Fame
interface FastEthernet4/0/12
interface FastEthernet4/0/13
 description ENCSD7v
 switchport trunk allowed vlan 1,10,20,30,40,50
interface FastEthernet4/0/14
interface FastEthernet4/0/15
 description controller -39
interface FastEthernet4/0/16
 --More--          description ENCSD4
interface FastEthernet4/0/17
interface FastEthernet4/0/18
 description Wireless Controller ip 10.100.0.49
interface FastEthernet4/0/19
 description WLC-37
interface FastEthernet4/0/20
interface FastEthernet4/0/21
interface FastEthernet4/0/22
 description admin Lan Off
interface FastEthernet4/0/23
interface FastEthernet4/0/24
interface FastEthernet4/0/25
 --More--         interface FastEthernet4/0/26
interface FastEthernet4/0/27
interface FastEthernet4/0/28
 description Tony Hornick Lan Office
interface FastEthernet4/0/29
interface FastEthernet4/0/30
 description Lan Office desk test port
 switchport access vlan 20
interface FastEthernet4/0/31
interface FastEthernet4/0/32
interface FastEthernet4/0/33
 --More--         !
interface FastEthernet4/0/34
interface FastEthernet4/0/35
interface FastEthernet4/0/36
 description Tony Hornick Woodard
interface FastEthernet4/0/37
interface FastEthernet4/0/38
 --More--         !
interface FastEthernet4/0/39
interface FastEthernet4/0/40
interface FastEthernet4/0/41
interface FastEthernet4/0/42
interface FastEthernet4/0/43
 --More--         interface FastEthernet4/0/44
interface FastEthernet4/0/45
interface FastEthernet4/0/46
interface FastEthernet4/0/47
interface FastEthernet4/0/48
 description NAS1
interface GigabitEthernet4/0/1
 --More--          srr-queue bandwidth share 1 30 35 5
 priority-queue out
 mls qos trust cos
 auto qos trust
interface GigabitEthernet4/0/2
 priority-queue out
 mls qos trust cos
 auto qos trust
interface GigabitEthernet4/0/3
 priority-queue out
 mls qos trust cos
 --More--          auto qos trust
interface GigabitEthernet4/0/4
 priority-queue out
 mls qos trust cos
 auto qos trust
interface FastEthernet5/0/1
interface FastEthernet5/0/2
interface FastEthernet5/0/3
interface FastEthernet5/0/4
interface FastEthernet5/0/5
interface FastEthernet5/0/6
interface FastEthernet5/0/7
interface FastEthernet5/0/8
interface FastEthernet5/0/9
 description CameraWood1
interface FastEthernet5/0/10
 --More--         !
interface FastEthernet5/0/11
interface FastEthernet5/0/12
interface FastEthernet5/0/13
interface FastEthernet5/0/14
 description woodard outside south east camera
interface FastEthernet5/0/15
interface FastEthernet5/0/16
 description VLAN10-Wood-2ndFloor Hallway
interface FastEthernet5/0/17
 description Camera Security Server
 --More--          switchport access vlan 10
interface FastEthernet5/0/18
interface FastEthernet5/0/19
interface FastEthernet5/0/20
interface FastEthernet5/0/21
 description Woodard Lan Off Test B16-
interface FastEthernet5/0/22
interface FastEthernet5/0/23
 description Time Capsule
interface FastEthernet5/0/24
 description Switchboard computer
 --More--          switchport access vlan 20
interface FastEthernet5/0/25
 description Camera
interface FastEthernet5/0/26
interface FastEthernet5/0/27
interface FastEthernet5/0/28
interface FastEthernet5/0/29
interface FastEthernet5/0/30
interface FastEthernet5/0/31
interface FastEthernet5/0/32
interface FastEthernet5/0/33
interface FastEthernet5/0/34
interface FastEthernet5/0/35
interface FastEthernet5/0/36
interface FastEthernet5/0/37
interface FastEthernet5/0/38
interface FastEthernet5/0/39
 --More--         interface FastEthernet5/0/40
interface FastEthernet5/0/41
interface FastEthernet5/0/42
interface FastEthernet5/0/43
interface FastEthernet5/0/44
interface FastEthernet5/0/45
interface FastEthernet5/0/46
interface FastEthernet5/0/47
interface FastEthernet5/0/48
interface GigabitEthernet5/0/1
 priority-queue out
 mls qos trust cos
 auto qos trust
interface GigabitEthernet5/0/2
 priority-queue out
 mls qos trust cos
 auto qos trust
interface GigabitEthernet5/0/3
 priority-queue out
 mls qos trust cos
 auto qos trust
interface GigabitEthernet5/0/4
 priority-queue out
 mls qos trust cos
 auto qos trust
interface Vlan1
 --More--          ip address 10.100.0.5 255.255.248.0
 no ip proxy-arp
 no ip route-cache
 no ip mroute-cache
interface Vlan5
 no ip address
 no ip proxy-arp
interface Vlan20
 no ip address
interface Vlan50
 no ip address
ip classless
ip http server
snmp-server community private RW
 --More--         snmp-server community public RO
banner motd ^C Welcome to Woodard "
Banner MOTD ^C
ntp clock-period 36029525
 --More--         end
Woodard3750#
