DHCP and NTP in Cisco Catalyst 9600
Tarek2023
Can I use Cisco Catalyst 9600 as Dynamic Host Configuration Protocol and Network Time Protocol server? if yes, how to configure the Cisco Catalyst 9600 to act as  Dynamic Host Configuration Protocol and Network Time Protocol server?
Thank you in advance.
Leo Laohoo
A humble Raspberry Pi can be built to become a Stratum-1 NTP sever (The Raspberry Pi as a Stratum-1 NTP Server).
I recommend to include a PoE HAT.
NTP master <<- if this command accept by SW then SW can work as NTP server for all other network device
For dhcp is easy only you need
Ip dhcp pool <name>
defualt router <IP of SVI of vlan >
Dns server
Network <same subnet of SVI of vlan host connect to>
