DHCP client not RFC2131 compliant.
Mohamed Ramram
A 88x router is connected to a CMTS modem and gets an IP adres through DHCP.
From time to time a DHCP lease renewal fails at T1 or T2 (or sometimes both).
The reason for failure is probably the ISP DHCP server but is not important for this story.
The Cisco DHCP client only tries to renew the lease at T1 (unicast) and T2 (broadcast).
So after two tries the Cisco DHCP client gives up and waites for end of lease to obtain a new one.
But according to RFC 2131 the client should keep trying to renew the lease after T1 (or T2) has passed.
<quote>
   In both  RENEWING and REBINDING states, if the client receives no
   response to its  DHCPREQUEST message, the client SHOULD wait  one-half
   of the remaining time until T2 (in RENEWING state) and one-half  of
   the remaining lease time (in REBINDING state), down to a minimum  of
   60 seconds, before retransmitting the DHCPREQUEST message.
</quote>
Is the Cisco DHCP client not RFC compliant or is it possible to enable this behaviour with a command?
The word SHOULD implies that a vendor can ignore this part if there is a good reason to do so.
If this is the case and Cisco choose not to implement this part does anyone know why?
Mohamed Ramram
anyone?
Bug Id : CSCtl51139
Headline : IOS DHCP retransmission algorithm should be implemented for renew/rebind
What changed : Fixed In Versions : 15.2(1.14)T
Detailed Bug Description: https://www.cisco.com/cisco/psn/bssprt/bss?searchType=bugIdSearch&bugId=CSCtl51139
