DHCP Discovery packet loss
Experiencing issue with packet loss for broadcast DHCP discovery traffic between two switches over port-channel.
When performing wireshark analysis i see multiple DHCP discovery packets being sent out from port and i see those discovery packet hitting other ports on a switch but when i am performing DHCP packet debug on a switch with DHCP pool i am not seeing any entries for those discoveries.
Switch with DHCP pool is 9300x 10gig ports
Clients connect from 3850 switch stack with 1gig ports over port-channel
During low traffic utilization DHCP discovery packets cross port-channel without any issues but when there is increased utilization DHCP discovery timing out.
The only thing i noticed is output drops on port-channel interface.
Any suggestion?
5 Replies 5
try change hashing algorithm for port-channel.
Reza Sharifi
Can you post the PO config from both switches?
Also, can you check if you are using the same load-balancing method, e.g source-mac or source-des-mac on both sides of the connection?
on the 3850, the 'traditional' way to get rid of output drops was to configure something like the below:
qos queue-softmax-multiplier 1200
was working with Cisco tec it looks like control plane policing issue.
Just in case someone runs into the same issue.
------------------ show platform hardware fed switch active qos queue stats internal cpu policer ------------------
<example>
                         CPU Queue Statistics
                                              (default) (set)     Queue        Queue
QId PlcIdx  Queue Name                Enabled   Rate     Rate      Drop(Bytes)  Drop(Frames)
6    0      ICMP Redirect               Yes     600       600      349103597224  987298676
12   0      BROADCAST                   Yes     600       600      102580649    325870
Class-map: system-cpp-police-data (match-any)
0 packets, 0 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: none
police:
rate 600 pps, burst 146 packets
conformed 8803604872322 bytes; actions:
transmit
exceeded 105795709285435 bytes; actions:
drop
Solution is to disable un-necessary broadcasts, disable ICMP redirects on layer 3 interfaces. Also identified application on a network that is generating ICMP time-to-live exceeded broadcast messages which is in the same control plane queue as DHCP broadcasts.
