dhcp enable effect on lan
r.kukreja
is there effect on lan if i enable dhcp on router . i mean machine get ip address from router and all other machine gateway is router while any other machine request for dhcp ip address . any effect on lan performance bandwidth , latency etc.
jonathanaxford
Level 3
Level 3
Unless you are talking about a very high number of clients requesting DHCP info from the router, then performance should not be adversely affected.
What speed is the link to the router and how many clients are you talking about?
Many thanks
Jonathan
lan speed is 100 mbps and around 30-50 client
Rajat
can any body reply ?
Rajat
Rajat,
I agree with Jonathan. The impact of running DHCP will be negligible.
Best regards,
Peter
