DHCP excluded addresses
moses12315
I configured the Router to a specific DHCP pool . I put also the default gateway, name server etc. After that i configured to exclude some specific range of addresses. But when i write show dhcp ip pool ... i can not see the excluded addresses. How can i find them . Do i have to remember them or write them down.
Moses.
Richard Burts
Moses
If you do show run you should see the excluded addresses as part of the running configuration. You could also do show run | include excluded
Rick
Rick
Richard Burts
Moses
Rick
Rick
ankbhasi
Hi Moses,
You can see them in your running config.
"sh run | in exclude"
Ankur
Moses,
Both Rick and Ankur have provided the info to find the dhcp excluded address from the config.
To answer your specific question as to why the excluded address info doesn't show up with the 'show dhcp ip pool' command is because all the other values like network, default router, dns etc are configured under the dhcp pool mode whereas the excluded address is configured under the global config mode.
Sundar
