DHCP for VLAN enabled switch
kumar.law
I am using 3560 switch on which I have created 3 VLANs. I have also enabled Inter-VLAN routing on the switch.
VLAN 1 - 192.168.1.0
VLAN 2 - 192.168.2.0
VLAN 3 - 192.168.3.0
Now I am able to browse internet on PC's in all 3 VLAN's but I have to provide IP manually in all the PC's.
I want to provide IP dynamically to all the PC's in all 3 VLANs connected to switch. Is it possible to run DHCP services on switch? If yes then what is the command line?
Thanks in advance.
Law
Martin Parry
Level 3
Level 3
You will need to enable the dhcp service, then configure the pools.
conf t
service dhcp
ip dhcp pool VLAN1
network 192.168.1.0 255.255.255.0
default-router
dns-server
lease
ip dhcp pool VLAN2
network 192.168.2.0 255.255.255.0
default-router
dns-server
lease
ip dhcp pool VLAN3
network 192.168.3.0 255.255.255.0
default-router
dns-server
lease
This is just an basic example, and you may wish to add additional options. Please see the following url for detail config guide:
http://www.cisco.com/en/US/docs/ios/12_4/ip_addr/configuration/guide/hipdhprm.html
Hope this helps
Martin
Thanks a lot Martin. Your suggestion really helped to solve my problem.
Law
