dhcp for vlan no native from Catalyst 2950
lformelli
Hi ,
I have two vlans and there is an dhcp server for
hosts ip of vlan 1.
Can I distribute ip address in vlan 2 which is
no native on my network from an Catalyst 2950 ?
Does anyone advice my an a configuration example
or document about ?
Best regards
Lorenzo
Ganesh Hariharan
Hi ,
hosts ip of vlan 1.
or document about ?
Best regards
Lorenzo
Hi Lorenzo,
DHCP configuration in 2950 switches can be done by following commands check out the below link hope that help and if you want a dhcp request to be forwarded to other vlan or in other interface then you need to use ip helper address check out the link for configuring the same also.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_19_ea1/configuration/guide/swipaddr.html#wpxref74213
http://cisconet.com/tcpip/dhcp/107-how-to-use-ip-helper-address-to-connect-remote-dhcp-server.html
Hope to Help !!
If helpful do rate the post
Ganesh.H
