DHCP=IP assignment issue.
sameermunj
Level 7
Level 7
i am using cisco 871 router for wireless connectivity.the ethernet port is connecte to lan and users are connected to wireless interface.problem is users are getting connected to wireless network but not getting ip address from dhcp server.dhcp server reeachable from lan.even tried using internel dhcp server.if we connect teh laptop to ethernet port of the router,the laptop is getting ip from dhcp server but its not happeneing on wireless.
anyone can help on this.present config attached.
Hello Sameer,
of course you can use the subnet mask that is required no problem on this.
the configuration I've suggested will work it has been used by other collegues in other threads and is reported in C877 configuration guide.
>> Only the vlan is part of bvi or the ethernet port also which is connected in lan ????
this is the key point: in this platform ethernet interfaces are like switchports so bridge-group command is placed in the SVI vlan1.
by default all ports are switchport in Vlan1 (L2 broadcast domain).
see
http://www.cisco.com/en/US/partner/docs/routers/access/800/850/software/configuration/guide/wireless.html#wp999879
or
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/wireless.html#wp999879
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello Sameer,
you need to use IRB also for SVI Vlan1
int vlan1
no ip address
bridge-group 1
no shut
int BVI1
ip address 10.x.y.z 255.255.255.0
ip helper-address
no shut
the BVI is the interface with L3 information.
Hope to help
Giuseppe
i will check the same tomorrow morning and let u know the result.
anyway apart from the changes suggested by you do you suggest anything to be deleted from the present config ??.(Subnet mask on ethernet is /20 and not /24)
last time i tried making ethernet port part of bvi group but the bvi was not coming up even though ethernet port was up.this is just a observation am sharing with u during the testing.
Hello Sameer,
see
or
Hope to help
Giuseppe
We tried the same and its working.
Thanks for the great input.
Thanks again
