DHCP, ip helper issue
jafar.tarawneh
Guys,
should this work,
I have two routers on one side, with ip helper enabled, in HSRP mode these two router,
acorss the wan link, where the dhcp is, I have two routers, in hsrp mode also, with secondary ip on each router, the subnet of the DHCP server is the same as the main interface, not the secondary
here is a sample config:
Router config where the dhcp is needed:
interface FastEthernet0/0
description Customer LAN interface
ip address 32.80.228.131 255.255.255.128
ip helper-address 32.80.183.23
service-policy input PolicyMap_2
service-policy output PolicyMap_1
ip ospf cost 100
duplex full
speed 100
no cdp enable
standby 1 ip 32.80.228.129
standby 1 priority 110
standby 1 preempt
standby 1 track Serial0/0/0.1
router config where DHCP is:
ip address 32.91.247.130 255.255.255.128 secondary
ip address 32.80.183.17 255.255.255.0
service-policy input PolicyMap_0
ip ospf cost 100
duplex full
speed 100
no cdp enable
standby 1 ip 32.80.183.1
standby 1 ip 32.91.247.129 secondary
standby 1 preempt
thx
Richard Burts
Jafar
Based on what you have posted I would not see any problem with ip helper-address working, assuming that you have appropriate routing so the 32.80.183.0 is reachable from the first router and that 32.80.228.128 is reachable from the second router.
Since you are running HSRP on the first router, I assume that there is a second router on that segment. Have you also configured ip helper-address on the second router? I would think that you should so that if there is a problem and the first router is not functioning you would need the second router to forward the DHCP packets.
Rick
Rick
I added the global command: SERVICE DHCP on the two routers, where the clients are, this worked.
