Dhcp ip issue
Hii Team ,
I have a cisco router in which i have configured a dhcp pool of 192.168.1.0 255.255.255.0 i have assigned 10 pc as
static ip's . when i restart my router the dhcp pc gets dhcp ips but the static pc ip's not getting lived i have to manually do shut on shut
switch port or plug out/in cable. please suggest what would be the problem
have you excluded the static IP address form your pool ?
ip dhcp excluded-address low-address [high-address]
Can you post the config of your router ?
