I am setting up a remote CCTV site which has a Palo Alto 410 firewall, Cisco 1300 switch, HPE Aruba WiFi AP and a number of cameras and I am having a difficult issue with DHCP not working for the cameras. My switch is setup with separate vlans for cameras, WiFi and management and the DHCP is all handled by the PA firewall. My switch config is as follows:
vlan database
vlan 700-702,710,999
exit
interface vlan 701
name SAFE_CAMERA
ip address 10.7.1.1 255.255.255.0
interface vlan 999
name ISOLATED
interface GigabitEthernet1
channel-group 1 mode on
switchport mode trunk
interface GigabitEthernet2
interface GigabitEthernet9
port security mode secure permanent
port security discard trap 10
spanning-tree portfast
spanning-tree guard root
spanning-tree bpduguard enable
switchport access vlan 701
interface GigabitEthernet10
description CamSafeTurret2
interface GigabitEthernet11
description CamSafeTurret3
interface Port-Channel1
switchport trunk native vlan 999
switchport trunk allowed vlan 700-702,710,999
monitor session 2 destination interface GigabitEthernet11 network
monitor session 2 source interface GigabitEthernet1 both
monitor session 2 source interface GigabitEthernet2 both
While troubleshooting this issue, I have plugged the WiFi AP in to port 10 and a laptop running Wireshark in to port 11. Both the WiFi AP and the laptop get a DHCP address from the FW just fine but the camera will not. Using Wireshark, I watch for DHCP packets going to the 2 port channel interfaces (Ge1 and Ge2) while plugging in the camera and the WiFi AP. What I see in Wireshark is the following packets coming from the WiFi AP:
4052 978.108280 0.0.0.0 255.255.255.255 DHCP 516 DHCP Discover (No 802.1Q Tag)
4053 978.108280 0.0.0.0 255.255.255.255 DHCP 520 DHCP Discover (With 802.1Q Tag)
4054 978.109095 10.7.1.254 10.7.1.101 DHCP 347 DHCP Offer
4055 978.130217 0.0.0.0 255.255.255.255 DHCP 528 DHCP Request (No 802.1Q Tag)
4056 978.130217 0.0.0.0 255.255.255.255 DHCP 532 DHCP Request (With 802.1Q Tag)
4057 978.131352 10.7.1.254 10.7.1.101 DHCP 347 DHCP ACK
There are no packets reaching the firewall from the camera. If I restart the monitoring and add port 9 (the port the camera is connected to) to the session then, I see the following coming from the camera:
274 68.643379 0.0.0.0 255.255.255.255 DHCP 516 DHCP Discover (No 802.1Q Tag)
280 70.973466 0.0.0.0 255.255.255.255 DHCP 520 DHCP Discover (No 802.1Q Tag)
Obviously these aren't reaching the firewall because they're not tagged with the correct VLAN ID.
I can't see why my AP and my laptop have no problem getting a DHCP address but the camera can't?
