Dhcp not working
mgutierr
I have 3 vlans on a C9300 4 switches stack
have vlan 112 -> 172.16.112.0 (data)
       vlan 312 -> 192.168.112.0 (voice)
       vlan 221 -> 10.1.112.0 (wireless)
and a dedicated windows server for dhcp scopes for each single vlan. (172.16.0.109)
ping from the C9300 to the dhcp works fine
VLAN 112 is gathering dhcp but VLAN 221 is not , so any device connected from gi 4/0/31 to 4/0/48 is not getting
10.1.112.X address from the scope, if i do setup manually static ips on any device it works.
i'm pretty sure that you guys are going to be able to help me out
18 Replies 18
from the other end i got
show ip route 10.1.112.1
Routing entry for 10.1.112.0/22
Known via "eigrp 10", distance 90, metric 3072, type internal
Redistributing via eigrp 10
Last update from 172.16.254.112 on Vlan254, 22:40:01 ago
Routing Descriptor Blocks:
* 172.16.254.112, from 172.16.254.112, 22:40:01 ago, via Vlan254
Route metric is 3072, traffic share count is 1
Total delay is 20 microseconds, minimum bandwidth is 1000000 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 51/255, Hops 1
mgutierr
Let me answer myself on this matter:
the answer is pretty much related to DHCP protocol and how cisco handles it,
1st.
since DHCP sends broadcast traffic to a vlan it has to be controlled, so by default you just have to assign
an ip helper-address to manage dhcp requests out of your vlan.
2nd.
check if your switch has dhcp relay service enable, for my particular model (C9300) i did delete and option that was preventing dhcp to run : no service dhcp
hope it help somebody with the same issue
Agustin9991
Hi all,
I had the same problem and the solution was to add the following commands in the vlan interface configuration:
ip dhcp relay information trusted
ip dhcp relay information option-insert
ip dhcp relay information check-reply
i.e.:
interface Vlan1012
description Telefonia Placa 1
ip address 10.171.0.1 255.255.252.0
ip helper-address 10.103.0.1
load-interval 30
Then the relay started working. Removing the previous config it kept running
Best,
JimmyNguyen5830
You have statement no service dhcp on you running-config.
Remove that statement would fix your issue.
config t
service dhcp
end
wr mem
reload the switch if possible.
