DHCP on specific Vlan
grahamhyland
I have a 3650 on a site with many vlans, I want to make the switch a dhcp server and alow clients on vlan 7 to avail of the dhcp server.
I do not want to affect clinets on vlan 20 that use ip-helper to a wintel dhcp server on vlan 21.
I dont want vlan 7 clients to get dhcp from vlan 21
Is this possible?
Graham
5 Replies 5
cadet alain
yes it's possible.
just create a scope on this device for vlan7.
Regards.
Alain.
Thanks - How do I do that?
conf t
int vlan 7
the only option in here is ip dchp relay
Graham
lgijssel
Level 9
Level 9
Hi Graham,
This is possible. All you need to do is create a dhcp pool which matches the vlan 7 subnet.
As long as the ip ranges are not overlapping there is no chance of messing up.
Sample:
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t1/feature/guide/Easyip2.html#wp25541
regards,
Leo
So is it neccasarry to give the vlan an ip add ?
Latchum Naidu
Hi Graham,
It is possible.
Configure DHCP on your switch like below and apply ip-helper 1.1.1.1 under the particular vlan 7.
And for the rest of the vlans remain as the ip-helper wintel dhcp server.
Configure an IP address on the router's Ethernet port, and bring up the interface. (On an existing router, you would have already done this.)
Router(config)# interface ethernet0/0
Router(config-if)#ip address 1.1.1.1 255.0.0.0
Router(config-if)# no shutdown
Create a DHCP IP address pool for the IP addresses you want to use.
Router(config)# ip dhcp pool mypool
Router(dhcp-config)# network 1.1.1.0 /8
Router(dhcp-config)#domain-name mydomain.com
Router(dhcp-config)#dns-server 1.1.1.10 1.1.1.11
Router(dhcp-config)#default-router 1.1.1.1
Router(dhcp-config)#lease 7Exit Pool Configuration Mode.
Router(dhcp-config)#exit
int vlan 7
ip-helper 1.1.1.1
Please rate the helpful posts.
Naidu.
