DHCP Problem with trunk
Emmanuel Vilela
Level 2
Level 2
Hi guys,
I'm beginner on network, and today i would to know, why my packet tracer don't work.
I've one router, r_core, the encapsulation are configured
My sw_core is my bridge root (stp)
Linked to this sw_core i've two sw_distrib, all of port are trunk, and one switch for my 2 access point
Linked to the two sw_distrib, i've 3 sw_access for my PC and for my DHCP
i've 5 vlan, all of vlan are configured on all switch
For my address plan,  i take 192.168.10.0 like network and i do 5 subnet
But it's more easy if u download the pkt, u can see by yourself
I write all of the pkt description on the maquette
Link for pkt :     https://www.box.com/files/0/f/264155163/1/f_5788490712         or on the attachment
Thanks for ur help, and for me it's very important to know why my pkt don't work !
have a nice day!
It doesn't work because you have incorrect DHCP scope subnet masks configured on the server. If you fix it will be just fine.
Subnet mask:
0.0.0.0 --> to 255.255.255.224
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
5 Replies 5
Abzal
Level 11
Level 11
1. You need to configure DHCP relay on the router:
(Suppose your DHCP server is 192.168.10.252)
int f0/1.160
ip helper-address 192.168.10.252
int f0/1.192
2. And fix your DHCP scope with correct subnet mask. It should work.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Thanks u for ur answer Abzal !
But unfortunetly, my dhcp don't work ;'(
So, i add on my router (R_Core)
int f0/1.96
intf0/1.128
int f0/1.160
int f0/1.192
int f0/1.224
And i add this scope and subnet to my DHCP server
ip : 192.168.10.252
mask : 255.255.255.224
gtw : 192.168.10.253
i add my pkt update
have a nice day
Subnet mask:
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Oh my god
I took 20 minutes to do the model and configure everything, and during four hours I have not been able to solve the problem of DHCP, which was the mask I forget I had to ...
Thanks a lot!
You're welcome! I'm glad that it helped you.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
