DHCP RELAY
command0000
Hi guys
i have a problem on setting up DHCP relay, connecting to DHCP server on Windows 2012 r2.
i have a tree vlan and i want to get the dhcp on the scope i created on the dhcp server
Mark Malone
what way have you configured it , are you using dhcp helper , can you provide some further information ?
hi mark
i am now ok with the DHCP relay. but can you help me on the Link aggregation Group? i encountered error when i am grouping the port.
Please see the image
ERROR "I encountered Port gi1 belong to a vlan"
I don't use these SMB switches but I checked that alert and someone already had that issue
check this post and follow the answer marked as correct and see if it works
https://supportforums.cisco.com/discussion/11170491/sf300-lag-port-doesnt-work-lacp-will-not-enable
InayathUlla Sharieff
Agree with Mark on this.
Kindly provide the following data:-
DHCP server---connecting to which device.
how does your setup looks like?
Do you have cisco router/switches in the network?
Who is the dhcp relay agent towards the dhcp server?
Example:-
DHCP server-------router----Switch----Client.
DHCP server- Pool confiugred.
Router:- Check if this is the DG for users then on that L3 interface do you have ip helper address configured.
Switch:- Check f the client is on the proper vlan.
Inayath
