WS-X45-SUP7-E not working. Need help.
Insiyabi
I have a CISCO 4706e Core switch. The supervisory engine WS-X45-SUP7-E is not working with a green flashing light on the Status LED.
The Utilisation LED are glown green as follows: the 0-30% off and 30-100% in green.
No output is seen on the console cable. I tried the module on 2 other 4500 core switches but the behaviour was similar.
Can someone suggest me with some ideas on how i can try and fix it inhouse. Any thing which i can do to get it working.
Jaison
6 Replies 6
Leo Laohoo
Did you actually try to console into the supervisor card?
If you did, can you post the entire bootup process?
Since i am having similar problem to this one above
maybe you can help me
i Have Sup7-e with Flashing green light
Here is the output i am getting through the console cable
it stops at "diagsk10-post version 5.1.4.1" and just hangs there
I have tried booting up with different versions of IOS with same result
Rommon (G) Signature verification PASSED
Rommon (P) Signature verification PASSED
FPGA (P) Signature verification PASSED
* Welcome to Rom Monitor for WS-X45-SUP7-E System. *
* Copyright (c) 2008-2013 by Cisco Systems, Inc. *
* All rights reserved. *
Rom Monitor (P) Version 15.0(1r)SG10
CPU Rev: 1.1, Board Rev: 3, Board Type: 101
CPLD Moka Rev: 7.0x2643.0x5956
Chassis: Unknown( 255 )
MAC Address : 00-26-0b-79-69-60
Ip Address : Not set.
Netmask : Not set.
Gateway : Not set.
TftpServer : Not set.
Non-Redundant system or peer not running IOS
System Uplinks & Linecards have been reset!!
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
Management Ethernet Link Up: 1Gb Full Duplex
******** The system will autoboot now ********
config-register = 0x41
Autobooting using the first file from bootflash.....
Loading image !!!!!!!!!!!!!!!!!!!!!!!
Checking digital signature....
[bootflash:/cat4500e-universalk9.SPA.03.06.00.E.152-2.E.bin]
Digitally Signed Release Software with key version A
Rommon reg: 0x00004F80
Reset2Reg: 0x00000F00
Image load status: 0x00000000
Snowtrooper 220 controller 0x042FE452..0x044DFA01 Size:0x0057B4C5
Program Done!
[ 0.058281] pci 0000:00:00.0: ignoring class b20 (doesn't match header type 01)
Starting System Services
/etc/sysconfig/modules/platform.modules: line 12: export: `type"': not a valid identifier
Gunnar
This is the reason why the supervisor card will always boot into ROMmon.
The correct value should either be 0x2101 or 0x2102.
gunnarfreyr
I know this is an old thread but i have the same problem.
Were you able to find a solution?
Gunnar
Filip Po
This are the well known statuses of STATUS LED on Sup-7E:
The STATUS LED indicates the status of he supervisor engine.
  • Green— All diagniostic tests have passed
  • Orange— System boot or a diagnostic test is in progress.
  • Red— A diagnostic test failed.
  • Off— The supervisor engine is disabled or is not powered up.
First answer to this questions:
  • if no console output (and you are sure, console cable is working)
  • if no change on green STATUS LED to other of well known statuses
  • if no difference of Supervisor in another chassi
  • if slot for Supervisor is in use
  • if power supply has STATUS LED w green color
  • if fans are working
  • if no visible damage and missing parts on Supervisor blade
Then according to this document you have to Troubleshoot Backplain Modules with TAC: http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/hardware/installation/guide/78-14409-08/4500inst/05trblsh.html
