DHCP reservation
From my understanding configuring an exclusion will require you to manually enter a static IP on a device and a reservation will not take effect. So my question is that if you need to create two DHCP pools, one for the lease and one for the reservation, how does the lease pool understand not to issue out that specific IP address when the device that is to receive the reservation is not connected to the network?
Please remember to select a correct answer and rate helpful posts
2 Accepted Solutions
The lease is infinite once it has been allocated to host, you can see it in sh ip dhcp bind output.
Regards.
Alain.
most specific config (hardware-address, excluded-address) using  for the ip leasing
5 Replies 5
mrdogantr
     look links below.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a00800f0804.shtml
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfdhcp.html
for example;
ip dhcp excluded-address 172.16.2.1 172.16.2.10
ip dhcp pool TEST
 network 172.16.2.0 /24
 default-router 172.16.2.1
 dns-server 8.8.8.8
 lease 30
ip dhcp pool Test_User
 host 172.16.2.254
 hardware-address aaaa.bbbb.cccc
 client-name Test_User
hth
Muammer
My question is not how to configure a reservation but what is preventing the original DHCP pool to lease out the reserved address. For example using your example. What is preventing DHCP pool TEST from leasing out 172.16.2.254 when that machine is not connected to the network? Does the Test pool inspect other pools for reservations?
Regards.
Alain.
Ah ok I see. Thanks for clearing this up for me!
