DHCP Snooping Issue when changing host vlan
dfranjoso
Hello All,
I have several C2960 with IOS 15.0(2)SE4 and DHCP snooping configured
ip dhcp snooping
ip dhcp snooping vlan 1,10-20
When i have a untrusted interface configured with vlan 1, the Thin-Client host receives an IP Address via DHCP with no problem, but if i change the vlan on that Thin-Client host to 10, the host does not receive an IP Address via DHCP and the following error message appears:
%DHCP_SNOOPING-5-DHCP_SNOOPING_MATCH_MAC_FAIL: DHCP_SNOOPING drop message because the chaddr doesn't match source mac, message type: DH
Any suggestions?
Thanks!
David
Wilson Bonilla
Level 3
Level 3
Hello dfranjoso.
That's  a timing issue, because you had the PC connected to vlan 1. The switch learnt the mac address in vlan 1, once you change the interface to access vlan 10, the mac table was still pointing the host's mac address to vlan 1 and therefpre dhcp can provide with an ip address.
Do you have port-security configured as well? if so, then run the command "clear port-security dynamic" and try to reproduce the issue again.
Regards.
Wilson B.
By the way I forgot to mention this
Enabling DHCP Snooping MAC Address Verification
With DHCP snooping MAC address verification enabled, DHCP snooping verifies that the source MAC address and the client hardware address match in DHCP packets that are received on untrusted ports. The source MAC address is a Layer 2 field associated with the packet, and the client hardware address is a Layer 3 field in the DHCP packet.
To enable DHCP snooping MAC address verification, perform this task:
Command
Purpose
Step 1
Router(config)# ip dhcp snooping verify mac-address
Enables DHCP snooping MAC address verification.
Router(config)# no ip dhcp snooping verify mac-address
Disables DHCP snooping MAC address verification.
Step 2
Router(config)# do show ip dhcp snooping | include hwaddr
Verifies the configuration.
This example shows how to disable DHCP snooping MAC address verification:
Verification of hwaddr field is disabled
Router(config)#
This example shows how to enable DHCP snooping MAC address verification:
Verification of hwaddr field is enabled
Router(config)#
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/snoodhcp.html#wp1099635
You can also disable validation with the command.
Regards.
Wilson B
