06-14-2017 06:44 PM - edited 03-08-2019 10:58 AM
Hi, I have setup a network as per diagram attach and turn on DHCP snooping on access layer switch and distribution switch. After configure, an issue is all users at access switch are not able to get IP address. Can I know is it I need to configure DHCP snooping at Server farm switches and also trust the DHCP server? If yes, can I know how to configure the DHCP snooping over layer 3?
Here is the configure at access layer and distribution switch
Access layer
ip dhcp snooping
ip dhcp snooping vlan <vlan id>
no ip dhcp snooping information option
ip dhcp snnoping database flash:dhcp.txt
Up link port
interface port-channel<Number>
description <description>
switchport mode trunk
ip dhcp snooping trust
Physical port for up link
interface TenGigabitEthernet<port number>
channel-group <Number> mode active
End host port
interface GigabitEthernet<port number>
switchport mode access
switchport access vlan <ID>
switchport voice vlan <ID>
ip dhcp snooping limit rate 10
Distribution Switch
ip dhcp snooping
ip dhcp snnoping database bootdisk:dhcp.txt
Up link port
I also insert this 3 command at access switch and distribution switch, but it also not work
ip dhcp snooping information option allow-untrusted
ip dhcp snooping database write-delay 30
ip dhcp snooping database timeout 30
John
06-15-2017 12:19 AM
this should work as designed. Have you configured your access ports with 'spanning-tree portfast', and (optionally, depending on your network design) the trunk ports with 'spanning-tree portfast trunk' ?
