DHCP snooping on 3750 FE port but not on GE port - why?
jkeeffe
Level 2
Level 2
I have a 3750 switch (c3750-ipservicesk9-mz.122-55.SE3) that I am configuring DHCP snooping on.
I can configure dhcp snooing trust on a FE port, but can't on a GE uplink port - there is no snooping option under that interface as you can see below.
VoIP-MDF-RS3750(config)#int f1/0/47
VoIP-MDF-RS3750(config-if)#ip dhcp ?
  client    DHCP client configuration
  limit     Limit DHCP Lease
  relay     DHCP relay configuration parameters
  server    Configure DHCP server behavior
  snooping  DHCP Snooping
VoIP-MDF-RS3750(config-if)#int g1/0/1
How do I trust the GE uplink of the switch for DHCP snooping?
jkeeffe
Level 2
Level 2
I figured out why the GE port doesn't allow for 'ip dhcp snooping trust'.  Only an L2 port can have dhcp snooping trust on it - an L3 port doesn't have that option.  I had an IP address configured on the GE port, therefore no snooping trust option was available.
jkeeffe
Level 2
Level 2
Rajeev Sharma
Hey,
Configure the command switchport under Gig interface and then you should be able to configure snooping trust.
RS
