DHCP snooping on aggregated links
victorsotov
We have 3560G(IP Base 15.0.2.SE4) as core and 2960's on access.
We enable DHCP snooping on all switches with uplinks on 2960's and links to DHCP servers on 3560 configured as "trusted". All worked fine.
Then we enabled link aggregation(two gigs between 3560 and each of 2960's) and our users stopped to receive IP-addresses. We tried all type of link aggregation(pagp, lacp, etherchannel) with no result. We disabled DHCP snooping on 3560 and users received they IP-addresses.
Does DHCP snooping works through aggregated links?
8 Replies 8
Hello
Have you trusted the port-channel also?
res
Paul
Kind Regards
Paul
Of course. On access uplink.
Hello
When you say access uplink do you mean -  the physical interfaces  or the logical interface of the port-channel or both?
res
Paul
Kind Regards
Paul
I mean port-channel interface of 2960.
#sh run int po1
Building configuration...
Current configuration : 78 bytes
interface Port-channel1
 switchport mode trunk
 ip dhcp snooping trust
end
#sh run int gi0/1
Current configuration : 108 bytes
interface GigabitEthernet0/1
 channel-group 1 mode on
end
Hello
As long as interfaces are trusted the snooping database does nothing else.
but listens on the the untrusted ports and snoops the ip & macs.
Also the snooping D/B will not be populated with existing clients,it will populate next time dhcp renews
So to confirm -
3560 - dhcp server(s) located ( dhcp snooping + vlan enabled -Access port and  aggregation links to 2960 trusted )
2960 -  dhcp snooping + vlan enabled ( aggregation links to 3560 trusted)
res
Paul
Kind Regards
Paul
No, downlinks from 3560 to 2960's isn't trusted because where are no dhcp servers on 2960's. When downlinks are just two gigs without port-channel - all works fine.
#sh run int gi0/51
Current configuration : 152 bytes
interface GigabitEthernet0/51
 description downlink-to-2960-01
 channel-group 7 mode on
end
1#sh run int po7
Current configuration : 92 bytes
interface Port-channel7
end
#sh run int gi0/3
Current configuration : 185 bytes
interface GigabitEthernet0/3
 description DHCP server
end
Hey,
Have you tried collecting packet captures on the port-channel and checked the DHCP (DORA) process, also check the logs for both the boxes for any syslog related to snooping.
HTH.
RS
Tom Vanhout
I experience the same issue. It seems to be related to the software version of 15.0(2)SE4
with ip dhcp snooping enabled it seems that if the packet is coming in via a port-channel, then requests,and informs are seen etnering the switch and are forwarded. (i see them on the next switch too). Discovers enter the switch, but don't seem to be forwarded. (i don't see them anymore on the next switch)
