DHCP snooping verify question
Andy White
Level 3
Level 3
Helo,
I'm just conencted to a switch and it has DHCP snooping, which I've configured before, here is the config:
ip dhcp snooping vlan 1
no ip dhcp snooping information option
no ip dhcp snooping verify mac
ip dhcp snooping
What I dont understand it what the command "no ip dhcp snooping verify mac" is on there for?
Why woul we use this?
Reza Sharifi
Form the config guide:
You can enable or disable DHCP snooping MAC  address verification. If the device receives a packet on an untrusted  interface and the source MAC address and the DHCP client hardware  address do not match, address verification causes the device to drop the  packet.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_1/nx-os/security/configuration/guide/sec_dhcpsnoop.html#wp1102732
What is the default?
By default, it is enabled.
so,
will disable it.
So having it turned off what verification is it doing, it seems to me it's as if it is turned off with that command as it isn't verifying the source mac address against the DHCP snooping database?
