DHCP snooping with DHCP relay problem
Andy White
Level 3
Level 3
I have set up a lab which is very similar to our live remote offices.  I want to enable DHCP snooping, but when I do clients no longer get an ip address.  The image below is just like my lab and our real networks and I have issued the "ip dhcp snooping trust" command on both trunk ports between the 2 3560s and the port on the 3560 connected to the router (switch0).
The debug shows this on switch0:
*Mar  1 01:07:16.950: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/1 for pak.  Was Vl30
*Mar  1 01:07:16.950: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Vl30 for pak.  Was Fa0/1
*Mar  1 01:07:16.950: DHCP_SNOOPING: received new DHCP packet from input interface (FastEthernet0/1)
*Mar  1 01:07:16.950: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Fa0/1,
3560-01#una MAC da: ffff.ffff.ffff, MAC sa: 0024.e8f9.6fee, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: 0024.e8f9.6fee
*Mar  1 01:07:16.950: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (30)
*Mar  1 01:07:16.950: DHCP_SNOOPING_SW: bridge packet send packet to cpu port: Vlan30.
3560-01#unall(Vlan10)
*Mar  1 01:07:16.958: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Vl10, MAC da: 0019.5578.e4b7, MAC sa: 0022.0c72.d841, IP da: 172.12.12.2, IP sa: 192.168.30.1, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 192.168.30.1, DHCP chaddr: 0024.e8f9.6fee
*Mar  1 01:07:16.958: DHCP_SNOOPING_SW: exclude source cpu port Vlan10 from output portset.
*Mar  1 01:07:16.958: DHCP_SNOOPING_SW: bridge packet output port set is null, packe
3560-01#unt is dropped.
*Mar  1 01:07:18.955: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Fa0/1 for pak.  Was Vl30
*Mar  1 01:07:18.955: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Vl30 for pak.  Was Fa0/1
*Mar  1 01:07:18.955: DHCP_SNOOPING: received new DHCP packet from input interface (FastEthernet0/1)
*Mar  1 01:07:18.955: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input inte
3560-01#un all
Do I have to set anything on the router?  Is this related to the option 82, which I'm struggling on understand in simple terms.
Reza Sharifi
Do you have the helper address configured on the SVI of switch0?
Yes you are correct.  Switch1 just has the trunk and both are using VTP, switch1 is almost acting as a L2 switch.  If I take DHCP Snooping off everything works fine and the PCs get the IP addresses from the server.
Hi Andy,
Have you tried configuring ip dhcp relay information trusted on the same interface of the router where the ip helper-address command is configured? I suspect that the router dislikes seeing DHCP client messages with the an empty GIADDR field and Option-82 present. Using the aforementioned command deactivates this check and allows the router to process the DHCP message.
Best regards,
Peter
