DHCP Static Binding on Cisco IOS
ppitts
We are replacing our Core L3 switch, but we would like to keep the DHCP bindings, so it will be less of a disruption.  Is it possible to export the current bindings from the old switch and import them into the new?
Francesco Molino
You can use the command ip dhcp database command to store all binding on a tftp or ftp drive.
Then if you configure the dhcpn pool on both switches, you'll avoid ip conflict.
Here a documentation you can read:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_dhcp/configuration/15-mt/dhcp-15-mt-book/config-dhcp-server.html
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
